Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 timing
Thread: 305 timing
Old 02-21-2003, 09:44 PM
wiretwister wiretwister is offline
Just finished a 78 trans-am with the same problem.The pontiac manual has this procedure.Bring #1 cylinder to TDC then turn crank with socket or wrench until timing mark is at 0 on the tab. Point the rotor button between #1&#8 towers on the HEI distributor then drop it in. Hopefully you do have an HEI distributor. GOOD LUCK
