-   -   305 tpi heads on 350 block (http://www.hotrodders.com/forum/305-tpi-heads-350-block-121728.html)
need4superchevy 08-07-2007 05:24 PM
i was just wondering if i can use the same distributor from the 305 or is there a special one that i will need im going with the same intake just going with 350 block instead of a 305 block. One more thing will i notice a real difference in power and torque. thanks for reading :confused:
DoubleVision 08-07-2007 06:19 PM
You can reuse the distributor. However, depending on the pistons and the 305 heads small chamber, the compression ratio maybe too high for pump gas.
need4superchevy 08-07-2007 08:54 PM
to high for pump gas
they are both going to be stock. could i just use an octane booster????
va4cqd 08-07-2007 09:38 PM
little bottles of octane booster does nothing. when they say 2 or 4 points, they mean like going from 87 octane to 87.2
