305 tpi heads on 350 block - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2007, 05:24 PM
i was just wondering if i can use the same distributor from the 305 or is there a special one that i will need im going with the same intake just going with 350 block instead of a 305 block. One more thing will i notice a real difference in power and torque. thanks for reading
Old 08-07-2007, 06:19 PM
DoubleVision's Avatar
You can reuse the distributor. However, depending on the pistons and the 305 heads small chamber, the compression ratio maybe too high for pump gas.
Old 08-07-2007, 08:54 PM
to high for pump gas
they are both going to be stock. could i just use an octane booster????
Old 08-07-2007, 09:38 PM
little bottles of octane booster does nothing. when they say 2 or 4 points, they mean like going from 87 octane to 87.2
chevy 350 heads on 305 coolcars58 Engine 1 05-21-2006 12:23 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
350 sbc..305 heads?? learjet60 Engine 6 01-28-2005 08:28 PM
putting 305 heads on 350 low77ride Engine 8 01-08-2004 03:43 PM
305 heads and a 350......not good.....so I am thinking this.. TheZaZ Engine 9 02-25-2003 07:33 PM
