Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305 tpi heads on 350 block
Old 08-07-2007, 06:19 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
You can reuse the distributor. However, depending on the pistons and the 305 heads small chamber, the compression ratio maybe too high for pump gas.
