305 TPI won't start without priming - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2010, 03:09 PM
Hello,
I'm posting for my father-in-law. He is building a 1939 Chevy 2 door sedan hotrod. He has a 305 TPI out of a mid 80s Iroc Camaro. He had a new chip burned for the computer and the engine ran on that computer when tested prior to rebuilding the engine. He rebuilt the engine and finished wiring the car.The car is nearly finished, the computer and all the wiring is installed.
The first problem is, the engine will only start by priming the intake with fuel. Once it is started it runs fine. It seems like the computer is not sending fuel to the injectors when the key is turned.
The second problem is, once the engine is started and running, the intake is making a loud "vacuum" noise. Any ideas why?
Please help.
Old 05-12-2010, 05:46 PM
Is the fuel pump getting 12V during engine cranking?
ssmonty
Old 05-12-2010, 05:58 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
For some years on those TPI intakes GM installed a ninth injector to handle cold starts. See if you have this and that its hooked up. Should be on driver side on back two runners.
305 Wont start SirMikesAlot Hotrodding Basics 4 10-26-2009 01:26 AM
305 TPI, -will not rev. 48DodgeCoupe Engine 9 04-23-2009 02:29 PM
86 iroc z 305 tpi 17withaniroc-z Engine 1 05-25-2006 01:21 AM
92 305 Tpi Problem!! 92camaroZ28 Engine 2 03-19-2006 12:59 PM
priming for 1st start w/new gas tank required? bullheimer Engine 4 08-09-2002 07:05 AM
