305 vrs. 307 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2008, 01:45 AM
305 vrs. 307 sbc
My 72 el Camino is using oil like the Valdez in Alaska. It was a no history 350 motor from someones 67 nova was good for several years, I still have the maybe original 307 that was
in the truck when I got it
and I have the chance to get another 76 el Camino 305 for the motor,to swap into my 72. Is one with the 305 versus the 307
better then the other. Fuel economy is now an issue not when I first put the 35o in a few years back. Your thoughts thanks Ed
Old 06-26-2008, 04:58 AM
RippinRon's Avatar
I'd say the 307 is better due to the larger bore diameter. There will be less valve shrouding than the 305.
Old 06-26-2008, 06:31 AM
I prefer the 305 ... for it's longer stroke. It has the same stroke as a 350 ...
I believe that the stroke makes more torque and torque is useful in moving a street geared, small cubic inch equipped vehicle.
Not much difference either way IMHO ...
Old 06-26-2008, 06:47 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
This thread has near-perfect timing for me. I have both in my garage now (the '69 307 has approx. 30,000 miles, and the '78 305 has 161,000), and I've been debating the same thing for quite some time. One of these two will end up with a fairly mild refresh in the not to distant future. Only because I'm flat sick of pushing a 4500lb car on and of my trailer. So, please let the info/opinions/feedback flow....
In a while, Chet.
Old 06-26-2008, 06:58 AM
305 vrs. 307 sbc
the 307 will need hardened valve seats running unleaded gas
unless it has been done already .
more power than the 305 ,being you might be hauling stuff .
Old 06-26-2008, 07:07 AM
schnitz's Avatar
Wiki Edits: 54
For mine, I was thinking about just doing a head swap from a 305 since it is otherwise unmolested. Most of the used 305 heads seem pretty reasonably priced in my area, so I figured they'd be a decent option, and might be for the O.P. as well.
For fuel milage, I'm thinking that the two should be dang close to the same. Any better thoughts than my semi-uneducated best guess?
In a while, Chet.
Old 06-26-2008, 08:27 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
I've always been under the impression that a 307 is actually quite a decent, underrated small-cube performance motor whereas a 305 was more of the economy work-horse. It would be slightly easier to get power out of the 307.
Torque will depend on what choices you make with the carb/intake/heads/valves and will be pretty much the same on either motor if built similarly.
K
Old 06-26-2008, 08:47 AM
schnitz's Avatar
Wiki Edits: 54
K
That sounds about right to me as well (which adds the complexity to the decision...).
In a while, Chet.
Old 06-26-2008, 09:46 AM
In a while, Chet.
That 'no mileage' 307 would be a straight drop in at my house... why mess with something that fresh?
If unleaded burns a valve, then vortec/manifold or performance 305 heads could be swapped on.
Ben
Old 06-26-2008, 10:58 AM
DoubleVision's Avatar
I would take the 305 heads and swap them over to the 307, I would also add a small rv cam to the 307 while I was at it. The stock cam in the 307 has a history of going flat. The 305 heads on the 307 would put the compression around 9.5:1, the small valves coupled up with a small rv grind cam along with a double roller timing set would give it all the torque you need.
Old 06-26-2008, 11:19 AM
sbchevfreak's Avatar
Licenced Automotive Technician
X2. I have run an almost exact combo like that, and it was very satisfactory. I had several people argue that a 307 could never pull tlike that, and It must be a , lol.
Old 06-26-2008, 11:50 AM
A 307 has the same stroke as a 327 ...
A 305 has the same stroke as a 350 ...
Which makes more torque ??
That is WHY the 305 would make more torque than a 307. Every thing else equal. Chevrolet already had the 307 ... when they came out with the 305 ... Chevrolet engineers decided that a 305 was a BETTER design for moving low compression equipped vehicles ... on todays watered down gasoline. Who am I to say they were wrong ??
Factor in the miles and the wear on your 305 VS the lower mile 307 ... if you just want to install a engine and go ... no question ... the lower mile 307 would be my choice. BUT ... both rebuilt and ready to install for another 100 thousand miles ... the 305
Old 06-26-2008, 12:00 PM
Wiki Edits: 3
I guess you have to assume that a longer stroke=more torque. I think that's a generally held assumption but I'm not sure if its true? For example, an oldsmobile 350 and a chevy 350 have the same cubes, but the olds motor has a shorter stroke and a bigger bore, yet its generally known that an olds motor, all else being equal, will out-torque a chevy motor. Another example is the buick and olds 455 motors, both with varying bore/stroke ratios, but very similar torque ratings (again, when all other things are equal/similar). That's generally why I think it has more to do with the length of the intake runners/valves...
K
Old 06-26-2008, 12:17 PM
31 five window
Last journal entry: grill and rear end
I have to go with Deuce on this one. The longer stroke means more torque. The comparison to the Olds or Pontiac 350,I believe the main difference is due to the better heads not the stroke.IMHO.
Old 06-26-2008, 12:28 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
I go with deuce too.. you have more options in my opinion with more stroke
307 sbc compression ratio's? C.W Engine 6 06-16-2007 04:37 AM
305 heads on a Chevy 307 75Guy Engine 6 04-30-2007 09:58 PM
307 to 305 engine/ transmission swap pjd Engine 6 08-19-2005 09:47 PM
Conversion of SBC 307 to 350! Houman SS '70 Engine 22 04-09-2005 12:09 PM
