305 Wont start - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2009, 07:56 PM
engine getting no fire ???
hey fellas ive got a 3-0-fried in my 70 monte, i just recently put a set of 601 casting heads on the block with a new intake,carb,headers,and a rv cam, well long story short i got it all put back together and its not getting any spark, the motor is turning over, the timing is dead on and all the wires i had hooked to the dist are hooked up. not sure what the problem is any help would be greatly appreciated.
Old 10-24-2009, 10:07 PM
Originally Posted by SirMikesAlot
hey fellas ive got a 3-0-fried in my 70 monte, i just recently put a set of 601 casting heads on the block with a new intake,carb,headers,and a rv cam, well long story short i got it all put back together and its not getting any spark, the motor is turning over, the timing is dead on and all the wires i had hooked to the dist are hooked up. not sure what the problem is any help would be greatly appeciated.
if your timing was off; or rocker adjustment wrong:orplug wires were mixed it still should buck;belch or pop....check dist. cap and make sure dist. electrical connector is plugged in.then check engine timming it could be out 180*
Old 10-25-2009, 01:10 AM
DoubleVision's Avatar
What distributor are you using? points or HEI?
Old 10-25-2009, 05:52 PM
it is a stock gm hei dist. the only wires on the dist are the ones from the rotor to the dist, the battery wire, and the tach. right? the plastic connecter for the battery wire was loose and will slip right off with a small tug..maybe??
the timing is dead on im sure of it, i checked tdc before i put the heads on and dist is pointing directly at #1.
also of course i did the cam and crank gear perfectly when i replaced the cam, im sure timing isent the issue.. something electrical...
Old 10-26-2009, 01:26 AM
Then it`s one of three things, since the HEI is pretty simple, it`s either the coil, the module or the pick up coil. It`s recommended the coil and module be replaced at the same time. You may want to check the wires going from the guts to the cap to be sure none are broken.
crank no start meev182 Engine 7 06-17-2007 06:27 PM
87 Bronco doesn't start kgm656 Engine 2 05-30-2006 02:00 AM
small block chevy cold start problem bennett Engine 7 04-09-2006 11:44 PM
Where is my 305 from?? Is it a ligit Chev Engine frankthetank Engine 2 10-25-2003 10:49 PM
Carb'd 305 to TPI 305, help? coolerow Engine 2 09-23-2003 03:10 PM
