Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 305ci with a 142 weiand supercharger
Old 03-05-2006, 06:58 AM
roy383ci's Avatar
roy383ci roy383ci is offline
hi
a friend of mine has a 1982 camaro
with a fresh rebuild 305ci in it (and wants to keep it that way!!!)
it is a 8.4:1 compression
hypereutectic pistons with moly rings
305 heads fully ported and a Little chamber work done
30 degree back cut on the valves in 1.84/1.5
headers 2 inch dual exhaust with 40 serie flowmasters
summit 1003 cam kit lift in/ex 442/465 122 lobe sep
k&n air filter
high out put accel coil
carb is an old 600 edelbrock
he wants to ad a weiand 142 supercharger on it
but we have no idea what carb to run on that motor with a super charger
he wants to make 325 to 350 hp would this be possible
on this set up
please give some idea's for a carb and cam
or does he need more boost than the 6psi it will make
thanks
