carb
I would have to say I would go with a 650 on the carb. Make sure it is a blower carb or if not make sure it is boost referenced. You do not want to run into detonation with those coated pistons.
As for a cam make sure the lobe seperation is around 112. Call the cam company and tell them the rest of your engine set up and they'll get you one that will work well with them heads and still get you out of the hole. As for right now stick with the 6 psi. as the stock pulley on mine made 6 also. You can always move up later. Another thing with these smaller units they are turning fast and make lots of heat. So upping the boost may create other problems. These units are great in my opinion. I have had no problems so far and I also have coated pistons with a little higher compression. Be careful have fun. Ron |
good advise, otherwise should work fine. Actually the Edelbrock 600 should work fine for that application. Im not usually a big fan of Edelbrock carbs, but they do a good job in draw through applications.
Id still recomend an MSD Boost controller. 305s are timing sensitive anyway due to the small bores & shrouded valves, add a blowers boost & your just making timing issues worse without a controller. John |
thanks for the info
the summit cam has a lobe sep of 112 so it would be good but will this make 325 350 hp or is the intake valve to small 1.84 or the cam. the car has a stock converter a th700r4 and 4.11 rear gears how much hp would a 142supercharger steel from the engine. thanks |
with a blower the intake valve size or port size, or port polish for that matter, arent very crucial, because the blower is stuffing the air in, the exhaust side is much more crucial. you might be in the 325 HP area, it should all be in within 5000 RPMs or so, itll be torquie, the 142 doesnt take alot of power to run & its a good choice for smaller engines like that.
| 305ci Timing Gear Marks Do Not Line Up | tcruise | Engine | 9 | 08-30-2005 06:22 AM |
| Wiend 142 or 177 blower? | chevyelc81 | Engine | 1 | 02-10-2004 06:29 PM |
| weiand 142 why no pop off plate? | 614streets | Engine | 15 | 09-29-2003 03:32 PM |
