306 build questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2007, 10:28 AM
mr.Pinto's Avatar
Ford's answer to tailgaters!
Last journal entry: My new project!!
306 build questions
I have 99% of my engine parts, just waiting on a Summit order, and then it's assembly time. Just a few questions.
This is my combo:
'88 306 roller block
SP forged flat tops (10:1 w/ 58cc chambers)
World Windsor Jr. 180cc heads, 58cc chambers (1.96" in / 1.60" ex valves )
Comp XE282 cam (.565 /.574 lift, 230 / 240 @ 0.05 duration. 2500-6700rpm)
Weiand stealth intake (1500 - 6500rpm)
600 cfm Holley DP
MSD pro billet / 6AL
I was told by my a few people that they think the intake and carb wont be able to keep up with the head/cam. I've heard great things about the Stealth intake, and read up on it before deciding on it. I was hoping with it's 1500 - 6500 operating range would give it a touch more bottom end on the street, but still perform well at the track since I don't plan on spinning much past 65-6600 rpm. Also, some people say I don't have enough carb, others say it shouldn't hold me back much.
Should this combo work OK, or should I not bother and upgrade now instead of later?
Also, what kind of HP should I expect from this. This is going into a Ford Pinto.
Thanks
Old 10-26-2007, 11:39 AM
How fast is fast enough?
I would go with better heads actaully- incase you decide to change your intake later to something more performance oriented. The rest looks fine for a mild street combo though.
Engine Build Questions BennyDigitale Engine 13 11-23-2006 11:03 AM
383 Build Questions Mustangsaly Engine 3 06-14-2005 09:53 AM
Chevy small block build up questions ccnova Engine 5 02-06-2005 08:23 AM
400 SBC project - questions... Mad Maggot Engine 24 01-05-2005 09:24 PM
First 4L80E build questions. bugsdad Transmission - Rearend 12 10-22-2004 07:40 PM
