Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 06-29-2006, 08:49 PM
Geterdun Geterdun is offline
307 to a 327 chevy
Just for general info, correct me if wrong. A 307 chevy has the larger diameter journal stroke of a 327, but the smaller bore of a 283, This block can be bored .120" to 4" then be a new 327 ready to build, with the larger, cooler running crank journals!
Find some 2x camelhump heads w/ 2 1/16" intake valves and you will be set!
  #2
Old 06-29-2006, 09:28 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
The 307 can't be bored .125".
Old 06-29-2006, 09:50 PM
DoubleVision's Avatar
DoubleVision DoubleVision is online now
Socially Unsociable
use a 350 block since it has the same bore of the 327 at 4 inches, bolt in the 307`s crank, use 327 pistons and you have a 327.
Old 06-30-2006, 11:59 AM
When I was grinding crankshafts for a living, we did bore some 283 and 307 chevy engines .120. Made the 283 a 302, to be built to 67-9 Rally Camero special engines. the 307, became 327, when people were unhappy with the 350.
A 350 that does not need boring, is probably still on the road. Of course, since you are buying pistons, yes, the 350 could be bored .030, for .030 o.s. 327, with the 307 crank.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "307 to a 327 chevy"
ThreadThread StarterForumRepliesLast Post
the history of chevy v8'ssavman1Engine3208-11-2010 12:30 PM
rebuilt chevy 327 small block wont fire78 NovaEngine301-12-2006 06:54 AM
1988 chevy s-10 blazer, and i want to put a 327 in it. comments, good idea bad idea.1969cssIntroduce Yourself112-22-2004 06:18 AM
307 Sb Chevy Rebuild??elvis 66 chevelleEngine409-11-2003 01:08 PM
307 chevy bolt on?HeathsterEngine701-10-2003 11:37 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
