307 to 350 swap. Flexplate and starter Q's - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2008, 12:01 PM
Sin7's Avatar
three weeks ago I decided it was time to give my impala a heart transplant. While I was at it, i opted to clean up the engine bay too. No point in working backwards down the road. The impala had a running 307 that It came with when I bought the car a year ago. The engine was strong but I wanted something fresh so I dropped in a rebuilt 350 that I had bought for another project that I sold. So here I am in week 3 of my transplant...
I used the flexplate and starter off the 307 and put it on the 350. Everything bolted up just fine. Behind that is a rebuilt turbo 350 that replaced the powerglide. The new motor and tranny are in, but I have yet to start it. After reading a few threads I think I might have caught a problem ahead of time........
Can the starter off a 307 be used on a 350 ?
Here is a before pic
And a current pic of what I've done so far..
Old 07-28-2008, 12:48 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
There are 2 different bolt patterns for 2 different tooth counts on the flexplates. One is staggered and the other is straight. As long as you have the threaded holes in the block for that starter, it will work. You already put it on, so give it a go..... Mainly because you said the starter & flexplate came as a working set, so you don't need to worry about tooth count.
Old 07-28-2008, 12:49 PM
F&J F&J is offline
Nice color, by the way
Old 07-28-2008, 01:11 PM
Sin7's Avatar
Yeah I reused the starter bolts from the 307 and they went into the 350 block just fine. I figured i'd be okay, since it was a "working set" as you put it, but I wanted to be sure before I started it. Thanks for your help.
The color is called Intense Blue Pearl off a dodge dakota R/T.
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 06:47 AM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
84' 350 SBC Starter Problems Gokussj5okazu Engine 8 05-14-2007 05:16 PM
1968 327 to ZZ3 350 conversion motorhead47 Engine 2 06-07-2004 11:05 AM
Starter and flexplate 400 with 350 crank in2classx Engine 2 12-01-2001 08:49 PM
