Thread Tools Search this Thread share on Facebook
  #16
Old 04-27-2008, 10:18 PM
SUPERSTOCK66X SUPERSTOCK66X is offline
venolia made custom pistons
Originally Posted by machine shop tom
Even 2 years ago to now, nobody makes a piston to work with a 3.75" stroke crank and a 3.875" nominal bore. If they did, it would be a 359 at .030" over.
tom
yes, its does make a 359.47 cid engine, the pistons i have are from venolia
they are for a 3.905 bore, 6" H beam rod and a 3.75 crank ground to 350
specs AKA a 383 stroker crank, the engine combination was built
by a engine builder for a guy running a dragster who tried to
set a class record as the block casting denoted that it was a 307
engine but was busted during a tear down. i purchased the rotating
assembly from a guy who was running it in a dirt limited late model
but went to a 434 cid engine
Register now (free) or login to remove ads
Old 06-26-2008, 03:22 AM
GMCTRUCKS's Avatar
GMCTRUCKS GMCTRUCKS is offline
307 engine.
A friend of mine had a 307 in his 55 chevy back in the 70's with a two barrel that thing would get after it after he replaced the clutch I ran him in my 70 GTO from the start he would hang with me but after a little bit I was gone I really liked that engine it took a beating he ran it with out a air filter and towards the end of when he had it the car would use 15 quarts of oil on a 350 mile trip it was funny because once he would hear the engine make a certain sound he would pull over and add 5 quarts of oil but she held up.
Old 06-26-2008, 01:49 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
Jake, With the price of gas going up your better off cleaning the 307 install 1.94 heads and get a cam that will give you torque. I had a 307 in my chevelle and got 18 miles per gallon. I was using a Q-jet carb. It ran pretty strong.
Old 01-26-2012, 11:37 AM
lojack lojack is offline
I am in the midst of redoing a 307, its out of a 68 gmc half ton, and its possibly for my 17 year old neice, so jam isnt an issue. Also its the original motor and theres somthing to be said for keeping things original if hp isnt what your looking for. That being said, when I dropped the block off to get hot tanked, the guy that I was nuts! He said this is either a 283 or 307, I said 307 he said they were smoggers lol. and I should just do a 350, but I kinda expained the situation and he said oh ok. I dunno if he agreed with my reasoning though, but hey whatever,
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "307 Chevy build-up"
ThreadThread StarterForumRepliesLast Post
finally finished chevy 350 buildredneckrodderEngine705-30-2011 06:03 PM
Desperately need carb for a '69 Chevy 307 vanonislandEngine201-13-2007 11:12 PM
trying to build a 55 chevytiresmoke55Introduce Yourself301-13-2006 07:11 PM
88camaro + 71' 307 chevy88camaroEngine210-03-2003 02:05 PM
307 chevy bolt on?HeathsterEngine701-10-2003 10:37 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
