307 in my '51 chevy pickup? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2009, 03:15 PM
Hi guys. This is my first post on here so plase go easy on my. I have a '51 chevy stepside that I have had for years and I started a v-8 conversion years ago but was stalled until just recently. The motor I got was a 305 small block or so I was told. I needed to order some parts for the motor so I wanted to find out what year it was. I looked up the casting numbers and found out it was a 68-73 era 307. I was pretty surprised to find that out but I want to know if having the 307 is better or worse than the 305. SHould it make pretty good power for my '51? I plan on it being a daily driver but I want it to have some get up and go too. The engine has an "RV cam", block hugger headers, a holley quadrajet carburetor and a KN air filter. Is this a pretty decent set up? Thanks for any of your advice.
Old 07-13-2009, 03:26 PM
The 307 is just fine vis-a vis a 305, its a 283 with a 327 crank. Yes some blocks can be bored to 4 inches making a 327 with 327 pistons. You need to sonic check the bores if you ever go this route, early 307s, like 283s, will bore to 4 inches, later ones with thin wall casting techniques are so-so.
A 305 uses a 350 stroke on a unique small bore, it cannot be made into a 350 with a boring bar; so the 307 brings some innate potential for enlargement with factory parts.
Bogie
Old 07-14-2009, 11:40 AM
If I had a 307 I think I would put a set of 305 HO heads on it. Port them out a bit and that should make a 307 run pretty well..
Old 07-14-2009, 12:37 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Bogie
I'll go one step farther. You can bore a 307 to 4" and use a 305 crank and use either 305 or 307 connecting rods, get 350 piston and you got a 350 motor.
Old 07-14-2009, 03:40 PM
DeathRattle's Avatar
Some Punk Kid
That 307 will run well for a long time, if your just usin it for a cruiser the RV cam will do you right
Only thing to watch out for is the nylon timing gear, if it still has one swap it out for a cloyes double roller and hit the streets
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
350 in a 51 chevy pick up dbcolston Engine 1 05-13-2009 10:10 AM
chevy camaro vs chevy pickup bolt pattern old fords Transmission - Rearend 2 09-19-2008 06:07 PM
62 chevy pickup rear end carrier into Bel Air Tymer Transmission - Rearend 1 07-30-2008 09:14 PM
51 Chevy Truck Tilt Frontend 51Panel Body - Exterior 14 07-28-2007 09:34 AM
