307 out of a 1971 malibu - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2010, 10:54 PM
I have a 307 outta a 71 malibu.(complete) It burnt oil when taken out and has been sitting untouched for 12years or so...i know thats not so hot tho either. I have 305 heads off of a 89 camaro rs. Id like to slap those on and an intake,have a single plane performer intake(edelbroc) and a stock(? cannot trust the guy who sold it to me) dont know the CFM quadrajet carb. I wanna know if all that will fit altogether with stock pistons and crank. I also have the stock 305 roller setup. Where to go from here???? PLEASE HELP ME, lol
Ryan
Old 09-07-2010, 11:09 PM
SSedan64's Avatar
Ryan
In your other Post you said this was a good motor.
Are you going to fix the oil burning problem? Hone & Rering Kit or Bore cylinders?
Most Q-Jets are 750cfm.
The 305 Heads, Intake & Carb will work fine.
The Roller setup wont fit in the older 71 Block.
Old 09-08-2010, 07:57 AM
dang, i was hoping i could swap it out to roller real cheap, lol. On a serious note, i actually havnt taken it apart at all im just gathering all the info i possibly can. See mostly ive delt with 305's and 350's, so the 307 is new. I do know its already a stroker motor, so to speak. But i can either hone depending on the cond of the cyl walls or bore .30 prefferebly. Any suggestions on a boreover? Do i have to change anything? I feel like a tard but if its technically a stroker i know things are a bit different, thank you for your input
Old 09-08-2010, 08:00 AM
I also know that pistons with certian over sizes(.20, .30,.60 over) are very hard to find. What to do, what to do,
Old 09-08-2010, 11:48 AM
DoubleVision's Avatar
If you can get away with just a cylinder hone do it, since aftermarket pistons are "destroked" as they are called meaning they have .020 off the compression height. If the 89 305 heads came off a TBI engine I would not use them as they are swirl port heads, the worst flowing heads in small block history. I would find some 416 casting 305 heads coupled up with a edelbrock performer plus cam, performer intake, Q-jet carb, small tube headers. Yes, the engine is a factory stroked 283, but that don`t mean anything different. It was the 283`s replacement as GM`s fuel economy engine. With the right pieces as I suggested, you can wake up the little 307 and make it run good.
Old 09-08-2010, 09:42 PM
Yeah those heads are off a tbi motor, dang, i might just piece it together anyways and clear my shelves off for more important things and other projects but i might be able to grab up some tpi heads. Thank you fro your help
I have chevy 1971 307 motor and i might need to sell it 88camaro Hotrodding Basics 4 09-07-2010 11:57 PM
1971 Malibu gear swap questions KFXrider88 Transmission - Rearend 1 06-18-2006 03:14 PM
valve tapping???? 69 chev malibu 307 malibuman Engine 3 11-29-2003 12:07 AM
overheating?? 69 chevelle malibu 307 malibuman Engine 5 11-02-2003 06:17 AM
bad starter? (revised) 69 chevelle malibu 307 malibuman Engine 7 10-30-2003 09:53 PM
