ok i just got my 1974 nova with a 307 yesterday, i have about $1000 to open her up for now can someone point me in the right direction, so far i was told the 305 heads so any other info would be great
thanks, PJ
If the engine is solid and in good shape you can do some low buck things to it. I am not really familiar with any differences between a 70 307 and a 74 307, but here goes. I suspect the 74 has smog heads and lower compression.
I will tell you what I did with my 70 Nova 307. Headers, Edelbrock Tarrantula intake, Holley 600cfm #1850, Crower 280 hydraulic cam & rev kit, Mallory ignition, and a Muncie 4 speed. If your car is an automatic these suggestions may hurt rather than improve the 307.
While many hated the 307, I sure don`t, when done right they will respond nicely. They came from the factory as a bottom of the barrell economy engine. The cams were known to go flat and take the rest of the engine with it. However, they came with flat top pistons which is a good start for you.
I would find a set of 416 casting 305 heads and do a bowl port on them. Then move up to a comp cams magnum 268H cam, this will give it a lopey idle but won`t kill off it`s low end torque. make sure you get the springs that match the cam. a double roller timing set. A set of small tube headers, dual exhaust with turbo mufflers and crossover pipe, a edelbrock performer intake, a Rochester Quadrajet carb, and a HEI ignition if it don`t have one already with the best pieces you can get for it such as spiral core plug wires, a brass terminal cap and rotor, add a advance curve kit and use one medium spring and one light spring. if the budget permits a flame thrower coil and module by pertronix. Take your time and route the plug wires carefully. Lastly add a k & n air filter. You`ll want to set the base timing at around 12 degrees btdc, then connect the vacuum advance to a full time manifold vacuum source.
One other thing, if you remove the timing cover and find it has a nylon coated timing gear I would remove the oil pan and clean the oil pump, as in time the nylon would get brittle and flake off falling into the oil pan, clog up the oil pump to the point it killed the oil pressure and seized the engine.
These small mods will wake up your 307, the best thing you can do for it next would be gears, a set of around 3.55 gears would suit you niclely.
yeah thats a lot of information to take in, yes its an automatic and the motor has 64 thousand miles on it.
1. what headers should i go with and the with 305 heads how much am i looking to get as far as power and are they just gonna bolt right up?
thanks for all the info you guys are great
I didn't have any information to base my HP figures on other than what the car weighed and what quarter mile times it ran. My best time was 13.20 and I estimated the HP at around 320-330.
ok so what am i looking at for horse power with my stock 307,
i kind of have my list of parts to order
1.hedman headers
2. 305 or 350 heads, im still finding out witch ones flow better
3.i might go with the 355 gears
4. some kind of intake manifold
If you use 350 heads it`ll have to be smaller chamber versions, some with 64cc`s. The heads on a 307 have 74cc chambers and most 350 smog heads have 76cc chambers. The early camel hump heads had 64cc chambers, but most of the time you`ll get some that needs completely rebuilt which gets expensive. Why I recommended the 416 heads is since they have a 160cc intake port, same as a 350, they have a 57cc chamber which will shoot your compression up to the 9.5:1 range where it should be, and they have a 1.84 intake valve which is bigger than the 1.71 valves your stock heads have. Plus the 416 castings are easy to find and cheap. The 305 is a small cubic inch engine like a 307, only there bore and stroke differ. Thats why the use of the 305 heads makes perfect sense.
If you follow the mods I gave it`ll be good for at least 100 ponies. Breathing is the point, but, thats also misleading. The engine is a air pump, the more you can push in the more performance it makes. However, you have to think of it all as a team. It has to all work together to give the given performance.
Now, I don`t recommend jumping on 350`s and larger small blocks with the same mods, as the rules are you can`t beat cubic inches and you can`t beat cubic dollars. But, even with a little guy 307, you can still make good performance when you give it the right pieces. If a 350 has the same or better mods but it don`t have gears you`ll blow it`s doors off. I watched a friend of mine`s built 350 with a bigger cam and camel hump heads get blowed away in the 1/8th mile by a stock ford ranger splash. My friends car had real high gears which was why it was easy to take the in 1/8th mile. So it goes to show, gears play a very important role as does the engine combination.
You can get surprisingly good performance out of a 307.
I build motors for, and race in a class that requires either a 305 or 307, and I build both, but prefer the 307 for myself. Even running the required cast pistons and other rules, they can run upwards of 7000 RPM's all day long, all season long. The 305 heads make a good, inexpensive choice. Some headers and a good intake would really help out, although we can't run them. A cam in the 220-225 duration range would work well.
like any V8 chevy, a 307 will respond will to a good intake/carb, headers/exhaust, cam, and better heads.
It is very important to match all the components (gear, stall, cam, compression ratio, intake, carb, heads, ect).
If you tell us what you want from the car it would help in the parts selection. for example: mpg important? what fuel octane? idle quality important? are you going to change gears and stall?
If you need to pull out the 307 then I would find an old 350 to rebuild then do a swap in one day.
what do you mean by matching all the components?
my nova is gonna be used at the track after winter so right now its build time
im looking to really open the 307 up with some heads and headers the car came with a flowmaster exhaust and an edlebrock carb so its almost there
after i get the heads and headers ill post back looking for some advise on a cam but right now im gonna take it one step at a time
i bought a 350 motor about a year ago and its been in my brother garage since then, it will cost more than $1000 to get that motor rebuilt and in the nova so im gonna stick with the 307
need to find out what gear. Or just plan to swap in 4.11 gears and a 3000+ stall. But if you buy these parts new then it will eat up most of the budget. Finding used parts maybe a good option for you.
You can make gains in power and still use the stock gearing and converter but the performance parts then you use should be designed for low rpm power. However, 4.11 gears and 3000 rpm stall (and traction) will make the biggest difference in a track car.
Another consideration would be to install a cheap set of headers, a used performer rpm intake, a used 3310 750cfm holley, a mild cam, and a 200hp shot of N02. This way you could use the stock gears and stall.
Are you going to run 1/8 mile or 1/4 mile?
A nova that came with a 6 cylinder engine would typically have a higher numeric gear ratio than a V8 car. You might be able to find a complete rear end in a junk yard for 150.00 with a 3.73 or 4.11 gear. do some research and find out what years interchange.
ok we put on the headers and intake manifold today and bought some shocks for the rear, it breaths a lot better and pulls a little harders but not a lot, can some one help me with what cam im looking for with this set up and im getting the 305 heads sometime next week to put on the 307
thanks
ok i looked, looked, then did a little more looking and this is the cam set up im gonna order unless someone tells me its not gonna work with the motor http://www.jegs.com/i/Comp+Cams/249/K12-234-2/10002/-1
feel free to let me know if this is a good kit to get, my budget is slowly going down so im trying to get good stuff without spending every penny on it, Ill have $200 left after i get this kit
A very good cam selection. It will keep the torque high. You won`t notice a big power difference until you swap the heads. But I have to ask, why did you swap the intake now? now you`ll have to buy new intake gaskets for the head swap. And keep in mind, do not use stock replacement fel pro gaskets. They don`t crush under a light aluminum manifold and will not seal, get the cheap mr. gasket paper gaskets hanging on the shelf. Coat the water ports with RTV sealer and your good to go.
the new intake was a must because of the old one, it had gunk in it and it wasnt sealing right so it was a must, but i didnt know that the heads wouldnt bolt up with the new intake...... woops :spank: .......i guess ill never do that again
I´m fixing my 307 whith 305 heads, preformer RPM manifold and a edelbrock750cfm. The cam will be a COMP XE262H http://www.compperformancegroupstor...Code=CC&Product_Code=K12-238-2&Category_Code=
Headers and a Flowmaster 2,5" dual exhaust. Hughes converter and a stock TH350. 3.08 in the rear.
The carb is a bit big but I had it for free and will try it on.
If you had the parts or where getting them for free then I would say yes build the 307 but... IMO putting $1000 into a 307 for performance use is like putting $5000 rims on a Geo. This is what I would do, buy a junkyard 350 with Vortec heads, Get a used intake manifold, a rebuilt carb off Ebay, cheap Headers, a Mild cam. Sell the 307 and you will get more HP and better gas Mileage for less money.
So in the end its going to cost an extra $300 to get a 350. The 307 will need heads anyway so your really not saving any money by keeping the 307.
Jordon
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
