307 small block - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2008, 02:40 AM
307 small block
I recently bought a rebuilt 307 small block chevy, with 352 heads and a hydraulic racing cam. the motor is stripped.. i was wandering how much hp and torque can i expect. i went an bought a 650 edelbrock carb and soon to buy headers, and suggestions???
its going in my 79 camaro.. the camaro came with a stock 250 straight six.. Will the 307 bolt on to the stock tranny or should i buy a new one? and what one?
thanks for any help you can offer.. im new here..
Old 05-19-2008, 08:38 AM
302 Z28's Avatar
The term "racing cam" is very general and offers no information on how this engine is setup. If indeed the 307 has been rebuilt as in bored with new pistons, be advised there are no good re builder pistons available for this engine. The stock re builder pistons have lower compression than the original GM supplied pistons. Given the information you provided it is virtually impossible to make a HP evaluation. A 307 in good shape is very capable of putting out 300+ HP with the proper selected parts. I had on in 1973 with a Crower 280 hydraulic and rev kit, headers, 600cfm Holley, Tarantula intake and a 4 speed in a 70 Nova that would run mid 13 second quarter mile times all day long. The 307 is not the dog most people think it is.
Vince
Old 05-19-2008, 03:32 PM
thanks for the info.. yeah we just recently bought it so .. as for knowing what all was done with.. out being told what was done is.. hard.. .. can i track serial numbers? on the parts the "guy" said he had put in.. ??? and where to find the numbers? i knew to all this.. thanks for any help.. you can offer
Old 05-19-2008, 03:50 PM
techinspector1's Avatar
Wiki Edits: 326
When I go to buy something like a car/truck/motor/trans/whatever and the seller tells me it has been "rebuilt", I thank him for his time and move on. I'd much rather buy a worn-out unit and do the work myself. That way, I know it's rebuilt and done right. Usually, when someone tells you that it's rebuilt, he's lying through his teeth.
Old 05-19-2008, 04:10 PM
I'll keep that in mind next time ... but, that does'nt answer my question..
Old 05-21-2008, 08:05 PM
Federal-Mogul discontinued their forged correct-height flat-top 307 pistons only a few years ago, so the pistons might be OK. Look for a part number on top of one.
And yes, the 307 will bolt to the trans. Use motor mount plates and mounts for a similar year Camaro with a 305 or 350 Chevy engine. Something from '75 to '81 should work, or maybe a '75-'79 Nova, although some of those cars came with non-Chevy engines. Use the flywheel/flexplate and starter from the six, and a front starter brace from a V-8 car.
You'll also need a fan shroud for a V-8 car, and hookups for electrical stuff, accelerator, exhaust, etc.
Old 05-27-2008, 07:35 AM
Thanks you... just the things i was wanting to know .. yeah i did'nt know if you could use the flywheel off the 6.. but, i guess so thanks alot for everything..
Old 05-27-2008, 08:54 AM
will i have to do anything with the drive shaft on my 79 camaro? im not changing the tranny so i don't think i would have to.. maybe dum ??
Old 05-27-2008, 10:56 AM
hotrod66_57's Avatar
Last journal entry: dolly
If you're not changing the transmission your drive shaft will be just fine. The only thing to think about would be maybe replacing the universals just to account for years of wear, or maybe to have it balanced too. Neither of those things would have to be done though, just housekeeping so to speak. The only thing you could worry about would be it not being strong enough, and frankly, unless you're making huge power I wouldn't worry about the driveshaft one bit. I got rid of the I6 in my 66 nova, replacing it with a 383, kept the driveshaft and it's worked out just fine! hope that helps.
hotrod
Old 05-27-2008, 11:31 AM
thanks alot it does help..
Old 05-27-2008, 01:17 PM
No there are no serial numbers to track. To see what was done the only solution is to take it apart, inspect and measure things.
350 heads on a 307 may or may not be a gift. Depending upon casting, the number can be found by removing the rocker covers, these heads can vary from around 58ccs to 78 ccs. This teamed with the piston can result in moderate to almost no compression on a 307. So to even figure compression you need to pull a head as you can have one of several combinations:
- a small chamber head with a flat top or domed piston will have high to very high compression.
- a small chambered head with a dished piston can have from moderate to low compression depending upon the size of the dish.
- large chambered head can have from moderate to high compression with a flat top or domed piston.
- large chambered head can have low to way too low compression with a dished piston
The only way to know this is to take it apart. Compression will also vary with head gasket thickness and piston crown to block deck clearance. As usual more of this makes less compression and lesser dimensions makes more compression.
"Racing" cams for whatever that means in duration, LSA, and lift usually need more compression to overcome low speed reverse pumping typical with large overlap cams with late closing intake timing.
Bogie
how strong is a 350 small block ChevyVan Engine 18 01-04-2007 11:27 PM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
400 small block idling problems 19nova72 Engine 15 04-16-2006 02:53 PM
small block or big block southrncuz1816 Engine 16 03-19-2006 07:40 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
