30's Factory Sound-deadening Removal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2010, 04:56 PM
36ChevyCoupe's Avatar
Hello!
1936 Chevy Coupe. Factory (I assume) deadening guard under headline.
Does anyone have any suggestion about removing this:
Short of scraper and elbow grease? I have removed the large portions and figure I would ask before I go further. I am installing current sound deadening (Fat Mat) and just do not think it will adhere that well if the glue used (and the padding left over) is left with out a good attempt at total removal.
My fear would be the Fat Mat would loose contact down the road and droop. The stuff sticks to anything I have found (prep is always done), but figured I would see if anyone has run into this before.
If I missed a thread, I apologize and bring the link forward.
Thanks
Old 07-31-2010, 05:08 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Moving to body /exterior..Nope nothing else but lots of elbow grease..I have used a small coarse wire cup wheel in my die grinder to get a lot of that stuff off of there..then shoot epoxy primer (prevents rust) and then apply the fat mat or whatever..
Sam
Old 07-31-2010, 06:26 PM
Whatever approach you take to removing that stuff, use a good respirator. And not the cheapie paper masks. Get a good respirator with replaceable cartridges. You only come equipped with one set of lungs, and it's hard to tell what's in that stuff.
Old 07-31-2010, 07:51 PM
Thanks One More Time. I figured as such.
I have found the tar like glue they used soften when you use mineral spirits or brake clean on it. Then (away from the spirits & brake clean) I warm a 3" putty knife via a map gas torch and it is come off pretty well. Not red hot as I do not want to transfer anymore heat threw the body metal than I have to. I have a painted surface on the exterior. Plus letting the sun warm the exterior helps.
Yes a dual cartridge respirator is being worn. Actually I used a spray bottle filled with water to wet the broken apart areas to help keep the dust down like they use with asbestos. I also clean up about every 15 minutes. It's coming along. I am actually moving on the the doors and the rear quarters. They did not use tar like glue to adhere this, so it is much easier.
Old 08-03-2010, 11:47 PM
Ended up with some great tips on how to make the removal of this stuff easier. When I transfer some pics from my camera I will explain further. Thanks again.
Old 08-04-2010, 06:56 AM
deadbodyman's Avatar
Wiki Edits: 11
I'm looking forward to that...the wire wheel ,putty knife ,resperator and safty glasses is a PITA.but the only way I know...(without heat)
Sound deadening & thermal insulation for a factory 5 Roadster Second Skin Rep Interior 12 01-08-2009 08:38 AM
Factory sticker/decal removal methods please cyclopsblown34 Body - Exterior 5 11-13-2007 07:43 AM
sound deadening??? charliec Interior 10 01-21-2007 04:13 PM
Knocking sound from the rear Arcuden Transmission - Rearend 1 08-14-2005 04:05 AM
What determines engine sound? Nightfire Hotrodding Basics 10 12-16-2004 06:45 PM
