30's Ford steering column bearing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2006, 07:37 PM
Kruzin Karl
Has anyone used one of these retrofit bearings in an older Ford steering column? Good, bad, any comments?
Thanks - Karl.
http://cgi.ebay.com/ebaymotors/1932-...QQcmdZViewItem
Old 11-27-2006, 12:21 PM
Rubber bushing to bearing conversion kits for early Fords
A bearing setup rather than a hard rubber bushing is always better. I'd have to challenge that 25% steering improvement claim though.
There are many components to good steering in early Fords.
Make sure you have your tires inflated correctly and your front end assembly is aligned correctly.
Make sure your steering components are in good shape and lubricated correctly, tie rod ends, kingpins, and steering box.
Make sure your steering box is correctly installed and that there is no interference in the steering column tube caused by misalignment of the box/shaft/tube assembly when installed in the frame(you may need to shim the box at the frame bracket to get good alignment and eliminate binding of the tube/shaft at the dash) and to the dashboard.
Make sure the steering has been adjusted properly by the Ford procedure with the pitman arm or drag link disconnected. Any adjustment made with steering linkage hooked up is a mistake.
That said, the bushing conversion may make a definite feelable difference...... or not.
Old 11-27-2006, 02:39 PM
Kruzin Karl
Well, my goal is to take an original column, put a bearing top and bottom, and run a Mustang II rack off of it. This seemed like a means to doing that.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Ididit Shorty Steering Column Question seadog Suspension - Brakes - Steering 2 05-10-2006 03:47 AM
steering on a 51 ford car 51FordDuff Suspension - Brakes - Steering 1 04-09-2006 05:19 PM
39 Chevy Steering Column Beenaway2long Suspension - Brakes - Steering 6 01-08-2004 04:52 PM
steering column + new wiring stea Suspension - Brakes - Steering 2 12-13-2003 07:08 PM
