30W oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2013, 09:24 PM
mitmaks's Avatar
Last journal entry: Grille
30W oil
Can i use 10w30 oil in my lawnmower even though it calls for 30w? What would be downfall to it, if any?
Old 05-31-2013, 10:44 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Briggs & Stratton ???
If so, you can apparently enter your engine model number and check the user manual to confirm.
For information regarding the oil capacity for your engine, please visit our Oil Capacity FAQ.
Oil Recommendation
SAE 30 40 F and higher (5 C and higher) is good for all purpose use above 40 F, use below 40 F will cause hard starting.
10W-30 0 to 100 F (-18 to 38 C) is better for varying temperature conditions. This grade of oil improves cold weather starting, but may increase oil consumption at 80 F(27 C) or higher.
Synthetic 5W-30 -20 to 120 F (-30 to 40 C) provides the best protection at all temperatures as well as improved starting with less oil consumption.
5W-30 40 F and below (5 C and below) is recommended for winter use, and works best in cold conditions.
Type of oil to use
Use a high quality detergent oil classified "For Service SF, SG, SH, SJ" or higher.
Do not use special additives.
Choose a viscosity according to the table above.
Old 06-01-2013, 06:53 AM
delawarebill's Avatar
oil
i've been using 10/30 in my rider for 8 yrs since new.. still holding 25# pressure at hot idle.. runs ~40# while cutting.
Old 06-03-2013, 06:51 PM
You can probably run 10w30 OK but it needs to be a quality oil that can take the heat of an air cooled engine. If loaded the oil temperature can be a lot higher on your mower than it is on your car due to combination of small oil capacity and limited cooling of the exhaust port area resulting in heating of the block and therefore oil.
Oil consumption due to possible sucking oil from intake valley..signs ? y2k600f4 Engine 10 07-31-2010 04:40 AM
Shell Rotella T 15W40 multiweight (CJ-4) vs 30W single weight (CF-4) y2k600f4 Engine 7 04-30-2009 08:09 AM
i have a 70 buick 455 fresh bottom end and new high out put oil pump still no oil pre tpisuper10 Engine 12 09-22-2008 09:26 PM
30w in a camaro go raiders Introduce Yourself 2 04-07-2008 07:35 PM
Vapor coming fro mthe breather and oil cap but not oil....????? 76 elco Engine 8 07-06-2007 04:35 PM
