31 32 ford five window coupes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2007, 02:18 AM
Hey guys I am close to buying a 31 Ford 5 window coupe that sits on a TCI chassis. I hope the pros here on the site can answer some questions for me.
1) What is the differance between a 31 and 32? Seems the 32's are more expensive.
2) The engine in the ride is a V6. Will putting a V8 be costly and what will be needed? The car has a chevy engine and auto trans.
Thanks in advance and thanks for putting up with my rookie questions.
Old 03-10-2007, 08:39 AM
Originally Posted by SuperSport
1) What is the difference between a 31 and 32?
About 10,000 dollars or more ...
This is a Model A sport coupe with a 32 Ford radiator shell installed. It also has the top chopped ( lowered )
This is a 32 Sport Coupe.
The 32 has a longer wheelbase ( 103.5 vs 106 for the 32 )
The doors are slightly longer.
The 32 has the fuel tank in the rear ( see the fuel cap on the cowl of the Model A )
The 32 has NO visor ... making a much smoother look ... and less wind noise.
The doors on a 32 fit flush ... they overlap on a Model A
A 32 has more room inside ( wider and longer )
The cowl is larger.
Henry Ford made over 4 million Model A's and 1932 was the worse year for America in the 30's ( the depression ) ... so there are well over 10 Model A's made for every 32 Ford. Ford only made about 2800 32 sport coupes if my memory serves me well ... I do not know the numbers on a Model A ... but I know they are considerably higher. 1932 was the last year that Ford produced the Sport Coupe body style.
As for the V6 to V8 ... it depends on the V6 installed. If it is the 4.3 type ... it could go very easily ... as the 4.3 shares the motor mount setup style and the bell housing pattern of a V8 small block Chevrolet. The 32 engine bay is longer ( because they came with V8's from the factory ... but the V8 ... is fairly easy to install in a Model A ...
Old 03-10-2007, 09:02 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
They are totally different cars that only loosely resemble each other.
A lot like the 60s-70s Mustang evolution or what happened to the early Novas.
Old 03-10-2007, 09:38 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
What Duece and xntrik have said gives you an idea of the differences in the body style and history of these two cars. There are also a big differences in the frames of these vehicles as well. The Westcott site will give you a very good look at the differences in bodies and frames. Go to the site and look at the differences in the original frames and the differences in the bodies of the Model A and 32 that they reproduce (check out the finished cars as well).
http://www.wescottsauto.com/
TCI built their frames to accommodate both the V6 and V8 so swapping a V8 into your A will not be too much of a problem. If you really want a V8 it may be cheaper in the long run to buy a rod with one already installed. Look around to see if there is a Model A with a V8 in it already and check out the price difference. It may not be worth your while in time and money to convert from a V6 to a V8.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 03-10-2007, 11:37 AM
As you can see from the TCI photos ... the 32's have a superior frame ... even stock. After TCI engineers one ... well see for yourself ... The 32 frame is longer, better braced and has much thicker side rails. There is a complete mechanical evolution generation difference in a Model A and a 32 Ford. The 32 has double curved frame rails ( each end ) ... which is stronger than a straight rail and allows the car to sit lower. The 32 chassis also costs a good bit more than a Model A from TCI ... more work, more metal and with the 32 ... they have to use 32 frame rails specific to a 32 ... with the Model A ... it is just box tubing. 32's have a beautiful curve indention in the frame ...
Go here for the Model A frame dimesions ...
http://www.wescottsauto.com/pdf2/FR-2.pdf
This has NOT been intended as a put down of Model A's ... I like them too ... but just a answer to your question.
Model A's look good too and can be a lot of FUN ... they are just different ... than some of the other choices. Lots of rodded Model A's on the road ... having fun
As a side note ... the next generation of Fords ( 33 - 34 ) are that much changed over the 32's ... a even longer wheelbase, even stronger frames and roomier inside the bodies.
Old 03-10-2007, 12:26 PM
DUH ... I read sport coupe ... when your screen name is super sport ... you asked about a 5W coupe.
Everything I said is still true ... just discount the sport coupe info.
Deuce Moderator
Old 03-10-2007, 12:56 PM
A big THANK YOU to you guys! In such a short time I have learned so much. You guys rock. I might look at the 31 closer now. It did have a 32 radiator shell wich made them harder for me to tell them apart. Any, more info would be appreciated. Great info. for us rookies. Thanks guys.
Old 03-10-2007, 08:36 PM
walt's Avatar
Maybe the other guys have answered your question but to add just a little: The Model A is slightly smaller than the 32. Model A's have the gas tank/ filler in the top of the cowl and a 32 gas tank is frame mounted in the rear. The Model A has overlapping doors at the rear and the 32 Is flush mounted doors. The Model A frame is much weeker than a 32 because 32 was the first year of a V8 option. If there is a 32 frame under the Model A that your looking at that is a good thing if you plan on running it without fenders.
Just my 2 cents
Building a 1932 5 Window Ford Coupe 32FordVA Introduce Yourself 3 01-28-2006 04:38 PM
Disc options for 32 Ford LittleTruck Suspension - Brakes - Steering 2 01-07-2006 10:21 PM
31 Ford PU Mike Wood Introduce Yourself 3 10-24-2005 10:29 PM
302 in 31 ford WilderRods Engine 10 03-26-2005 07:16 AM
HELP! New 32 Ford chassis issue RoadShow Body - Exterior 8 06-30-2004 06:50 PM
