31 chevy spindle threads per inch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2007, 10:40 AM
R Gassman
Last journal entry: 31 chevy Top on
Does anyone out there know the thread pitch on a 31 Chevy front spindle? 3/4 X ? I need to get a die to chase the threads further up the spindle but am having trouble determining the threads per inch. regular 3/4 fine is still to coarse.
Thanks
Gassman
Old 01-20-2007, 11:33 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You can get one of those multi-leaf (looks like a feeler gauge) thread gauges from Snap-On, etc. for a few bucks. Handy to have. Not sure if they include non-standard thread counts, though.
You might be able to hold a machinist ruler next to it and count the threads per inch.
Quick hint for other times.
Lay another bolt of the same diameter, thread to thread, into the other for a match up.
Old 01-20-2007, 08:46 PM
powerrodsmike's Avatar
Wiki Edits: 161
I dont know what the thread count on a 31 chevy spindle is but here is a pic of that pitch gauge.
And X is right, use any bolt with the matching pitch to determine thread count. The thread depth is dependent on the pitch, not the diameter.
If you need a nonstandard die check enco or rutland. The new
Rutland catalog lists 3/4" dies in 10,14,16,18,20,27,28,32,36,40 and 48 TPI.
They look chinese, so buy 1 for each side.
You may want to check the threadform with a gauge to make sure it is really 60*.
Are you sure you cant use a spacer under the nut?
Later, mikey
BE different....ACT normal.
Old 01-21-2007, 01:49 PM
Chopt 48's Avatar
Those gages don't cost much, You can even get one at
Sears or at most autoparts stores. You will find that you dig it out quite often if you have it.
Suggestion, take the nut with you to the parts house or hardware store and see if you can match it up with what you need. you might try one of the bolt and nut dealers around as they often sell taps and dies along with the fasteners.
I wouldn't buy a joe cheap thread chaser or die as they often miss the mark when it comes to thread quality.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
chevy guys, spindle interchange?? short step side Suspension - Brakes - Steering 13 09-05-2005 08:30 PM
Chevy Thunder and stonedchihuahua Jon Hotrodders Site Suggestions and Help 56 03-14-2004 06:47 PM
chevy guys, spindle interchange?? short step side Suspension - Brakes - Steering 0 02-17-2004 06:46 PM
2 inch drop spindle plus Suspension - Brakes - Steering 3 11-05-2003 11:33 PM
