'31 Chevy steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2006, 09:20 PM
PA-Farmer's Avatar
'31 Chevy steering
All,
I have a '31 Chevy 5w coupe that's had all the modern upgrades (350-350, 4w disc brakes, new wiring/guages, etc.) except the steering. It is bone stock and wanders a bit. There is a fair bit of play in the steering box but the remainder of the front end is pretty tight.
I like the look of the solid front axle and was told replacing the steering box and (possibly the column) would be just the ticket to more refined steering.
Does anyone have experience upgrading the steering box on a '31 Chevy? I'd like to hear the details if someone out there has done this upgrade.
Thanks
Old 08-14-2006, 10:45 PM
As a 1932 Ford owner and a Moderator here ...
I would like to WELCOME you here ...
I am not familiar with the stock steering box in a 1932 Chevrolet.
Is it cross steer or otherwise. A lot of rodders use a Vega cross steering setup ... with good results. A cross steer unit mounts on the left frame rail and goes across to the right side wheel. Some others mount on the left frame rail and go to the left wheel.
I have a Uni-Steer rack in my new 32 Ford project ...
This is a cross steer set up .
http://www.unisteer.com/product.php?...cat=250&page=1
I believe it would adapt to a 32 Chevrolet fairly easy ...
Old 08-15-2006, 03:01 PM
PA-Farmer's Avatar
Deuce,
Thanks for the tip on the unisteer; I checked out their web site and they do not make a unit specifically for Chevy so I'll need to contact them.
Anybody else out their with a '31 Chevy?
PA-Farmer
Old 03-25-2017, 03:22 PM
I have a 32 chevy and am using hydralic backing plates and drum braking system from a 56 chevy truck I am also using rack and pinion steering from a 2005 silverado
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Chevy Caprice steering column work - Rack Kit ViperMonster800 Suspension - Brakes - Steering 8 06-04-2006 04:43 PM
Power steering for a 51 Chevy B-210 Suspension - Brakes - Steering 3 08-23-2005 10:03 PM
changing manual steering to power on 63 Chevy II Mustangsaly Suspension - Brakes - Steering 10 07-19-2005 04:21 PM
Chevy Tilt Steering Column James Groves Suspension - Brakes - Steering 1 11-20-2001 04:12 PM
