31 ford disc brake suloution - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2005, 04:25 PM
I have found that 96 ford 4x4 truck front rotors fit the hub after you mill 1/4 inch off to go in the hat. Then you clear off the original backing plate and cut a u in the top at center for the caliper,it only takes a little time to make it fit perfect. When you are done all you had to buy was the rotor calipers and pads. I think this is a very good setup any comment's anyone? Thanks.
Old 05-01-2005, 06:27 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Cool
That is what this is all about..finding those workable solutions..good job..
OMT
Old 05-01-2005, 06:31 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
PICTURES.....please....joe
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
32 ford manual/drum brake cylinder? help! zuppamon Suspension - Brakes - Steering 2 10-27-2004 05:30 PM
Brake system in 1936 Ford Pickup old_tin Suspension - Brakes - Steering 1 10-16-2004 06:05 AM
Ford 9" w/ rear disc brakes 48Man Suspension - Brakes - Steering 8 07-21-2004 07:58 AM
Disc brake conversion on Ford 9" shockers69 Suspension - Brakes - Steering 1 07-01-2004 10:26 PM
