31 ford rear buggy spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2002, 06:53 PM
Angry 31 ford rear buggy spring
31 ford stock frame and rear crossmember.Pete and Jakes 4bar. Posies buggy spring. 8" ford rearend. Spring perches @46". Car seems to sit 4-5" to high. Granted not all the weight is in the car yet. Shocks are @ full extension. Will it settle down with all the weight on? Want the wheels tucked into the fenders.
Old 11-12-2002, 09:07 PM
BOBCRMAN@aol.com's Avatar
Post
with the buggy rear set up the only way you can get the rear down is to move the spring up, this is why they used to z the frame on these old cars. this will get you down where you want to b. the way you are now with all the weight on it you may get 3-4 inches max of lower ride height with reversed eye springs and shackles that just clear the axle.
