Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 31 ford rear buggy spring
Old 11-12-2002, 09:07 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
with the buggy rear set up the only way you can get the rear down is to move the spring up, this is why they used to z the frame on these old cars. this will get you down where you want to b. the way you are now with all the weight on it you may get 3-4 inches max of lower ride height with reversed eye springs and shackles that just clear the axle.
