31 ford tudor - sagging doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2009, 04:50 PM
earlf31's Avatar
Shorty
I have gaps at the top back end of both doors. If I lift up on the door, I get a small amount of movement but, not enough to close the gap. There doesn't seem to be any wear on the hinges but, I really can't tell. The front seam (opening) where the door meets the cowl is pretty much lined up. I purchased a door kit, (rubbers, top & bottom) from MAC but, when you look out the top of the doors from the inside, the rubbers do not even touch the top of the door frame. Any and all suggestions would be appreciated.
earlf31
Old 05-08-2009, 05:14 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Have you checked to see if it is the body sagging instead of the doors? Cole
Old 05-08-2009, 08:43 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Sounds like you need to move the B pillar down in relation to the A pillar that the doors are hung on. What you are doing in effect is lowering the rear half of the body while leaving the cowl in the same relative position. That should tighten up that gap. Depending on what you have in place for body shims right now determines how easy this all will be.
Andy
Old 05-09-2009, 06:23 AM
32chevy vett's Avatar
32chevy vett
sagging doors
Your body/frame mounts need more spacers near the back of the doors.
The doors are good. The body needs a lift.
Old 05-09-2009, 07:13 AM
da34guy's Avatar
Shim the body up in rear !!!!
Old 05-09-2009, 08:04 AM
Frisco's Avatar
Glad To Be Here
The Model 'A' Ford door alignment (as well as the hood alignment) is accomplished by shimming the cowl. The shims are usually placed under the cowl between the lower body (subframe) and the running board apron in line with the windshield posts for the door alignment.
Old 05-09-2009, 08:07 AM
Frisco's Avatar
Glad To Be Here
Correct approach, BUT, wrong location. Adding shims in this area will INCREASE the gap between the top of the rear portion of the doors.
All the shimming is done in the cowl area.
Old 05-09-2009, 09:09 AM
Listen to Frisco, shim the BACK of the cowl, the bolt closest to the door and this will raise the back of the door.
And be sure you tighten it all down to determine what it did for you. If you loosen the cowls bolts on one side, then put a shim (it doesn't have to be permanant at this point) then tighten down your bolts, ESPECIALLY the front one, you will see the door move. But you have to tighten the front bolt back down or the shim in the rear bolt will do almost nothing.
This is after you have checked all the hinges though. Be sure the hinges are tight, lift up on the rear of the door and see if there is any slop, if there is determan where it is. If there is report back with that info and we may have some suggestions.
Old 05-09-2009, 01:36 PM
earlf31's Avatar
Shorty
Thanks to everyone for their input. I will shim the back of the cowl as suggested and let you know how it turns out. Don't know exactly when, I have to get approval to sneak it in on my wife's "TO DO" list.
earlf31
Old 05-10-2009, 04:31 PM
32chevy vett
sagging doors
I just wanted you to know I was WRONG! I had to go look,as soon as I looked at it, I know I goofed. Frisco my first street rod was all most a twin to your primer low boy in your photo gallery.1960 how the price of things have changed.
Rear Leaf Spring Installation on 31 Ford 31fordcoupe Suspension - Brakes - Steering 32 04-24-2009 08:08 PM
31 ford 5w coupe 55rat Hotrodders Site Suggestions and Help 1 03-09-2007 04:42 PM
1939 Ford Deluxe Coupe doors CarGuy70 Body - Exterior 3 09-14-2005 06:00 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
fenders, doors and such 1935 ford beetle9 Body - Exterior 2 03-29-2002 05:18 AM
