31 model a coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2008, 04:03 PM
Dons31A's Avatar
31 model a coupe
I purchased a power window kit from electric-life EL02 power window co. I called the rep first to ask if this would fit in my door. He told me he heard of people installing in a 31. I received the unit and tried to install it without too much mod. I found that there is not enough room in the door. Has anyone installed this kit in a 31? Also has anyone mounted bear claw latches in the door. Any help will be appreciated. Don.
Old 04-29-2008, 04:13 PM
life is a temporary assignment
Some of the kit's have to be cut to fit.
Old 04-29-2008, 07:12 PM
Metal Twister's Avatar
Change is Opportunity!
Last journal entry: One More Seat
There just int enough room to clear the window. I put the bear claw in the door post and put the striker in the door. With the solenoid lower in the door post, or below the "B" pillar. Even that doesn't look very good IMO. In fact, before its all said and done I will probably do something else. I can post a pic or two if you would like?
Old 04-30-2008, 05:44 AM
Dons31A's Avatar
31 model a
Thanks for the info. Yes, I did see someone else put the latches in the B pillar. It looked like it would work fine, but I guess not. Please post pictures. Do you have power windows? If so, please pictures also. Thanks again. Don
Old 04-30-2008, 06:39 PM
Here are a couple of pics that show what my solution the the problem was. Im still undecided as far as the windows being powered by electricity, or elbow. Hope this helps... Bob
ID:	29644   Click image for larger version
Old 05-01-2008, 11:16 PM
powerrodsmike's Avatar
Wiki Edits: 161
Specialty power windows has a bolt in kit specifically for a Model A.
http://www.specialtypowerwindows.com/modelAfords.htm
I've used the slimline rotary latches in model A s and Ts..
http://www.allegiscorp.com/DisplayPa...t+Slam+Latches
Many of the replica body manufacturers are selling that latch these days as well as some of the street rod specialty houses.
later, mikey
BE different....ACT normal.
Old 05-02-2008, 09:07 AM
Dons31A's Avatar
31 model a
Thanks everyone for the replies. Good job on the bear claw latches. Yes, I have seen the power window setup for the model a specifically. I just didn't want to pay that much. I guess you get what you pay for. My mistake. I guess what I will do is sell the electric life window kit and buy the model a kit. Has anyone installed the latches from the web site posted in the previous reply? Thanks for everyones reply. Don.
Old 05-02-2008, 09:12 AM
Dons31A's Avatar
31 model a
Mikey, do you have any pics with the installation of the slimline latches? Boy that would be a lot of help. Do you mount these in the door or door post? Location would help. Thanks again.
Old 05-02-2008, 10:01 AM
Wiki Edits: 161
I have no pictures, those slimline latches were installed in the doors of the replica roadster bodies I used to build at Poli-Form. You can call them if you'd like. In your case you should think about putting the latch in the B pillar, as the window mechanism and channels get in the way in a closed car.
The Allegis website I directed you to is one of the main suppliers of hardware to body manufacturers. I posted that link to show the dimensions of the latch ..You may be able to buy from them.
Or I just found out that Tri Mark, the manufacturer of that latch, now sells direct to the public...
http://www.trimarkhardware.com/en/zP...intParentid=87
http://www.trimarkhardware.com/en/zp...6&id=36&skuid=
Later, mikey
28 Model A coupe 1 Car Garage Introduce Yourself 2 01-21-2007 07:01 PM
IFS on 31 coupe (i want it gone) pi71 Suspension - Brakes - Steering 5 12-12-2006 10:27 PM
Centerline, its the Idiot Model A Coupe Builder littledave Hotrodders' Lounge 86 09-03-2006 01:21 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
interior for 31 coupe dcurhotrod Interior 1 11-08-2002 08:03 PM
