31 model a coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2013, 01:56 PM
31 model a coupe
I want to reconfigure my trunk area. I'd like to make it bigger by rearranging how the water is drained from the rain gutters. Any ideas?
Thanks for sharing your experience!
john
Old 03-25-2013, 02:54 PM
33Willys77's Avatar
Post pictures of what you have now - that will help. You can remove the bottom gutter and make a smaller one - have a hole in each corner with a drain hose. That would open that area up, but it will take some building and body work.
Old 03-26-2013, 07:44 AM
Irelands child's Avatar
You can't do much with the side or top/forward gutters. The one formed with that panel across the bottom/rear can be straightened a bit to be more perpendicular, but for the amount of work, very little gain. That area has to drain, and it does via holes in the end of that rear, lower piece. If the floor is a slanted for a rumble seat, that can be flattened pretty easily if not needed and gain a lot more useable floor space. If you have a gas tank in the trunk instead of the cowl tank, consider either the 'Tank's Inc' saddle tanks or modify the rear of the frame for a '32 tank - not easy or even cheap, but works great. See Dagel's website or do it yourself as I did using easily available materials.
Irelands child
31 model a coupe Dons31A Hotrodding Basics 8 05-02-2008 10:01 AM
31 Model A coupe speedydeedy Hotrodders' Lounge 47 11-29-2007 09:42 PM
28 Model A coupe 1 Car Garage Introduce Yourself 2 01-21-2007 07:01 PM
Model A Coupe rodsterv8 Introduce Yourself 2 03-03-2006 01:26 PM
model a coupe racur96 Body - Exterior 1 09-12-2003 10:33 PM
