Thread Tools Search this Thread share on Facebook
  #1
Old 01-16-2012, 02:29 PM
golferjc golferjc is offline
31 model a coupe patch panels
I'm installing patch panels on the lower body behind the doors and in front of the rear fenders. My problem is the panel wraps around the door post which is made of wood. I don't want to cut the door post out to weld the panel. Can I just weld up to the wooden post and then put a nail in thru and cover the seam and nail with lead? Would this hold up? Would there be issues with the paint?
I'm just a weekend body man so I need all the help I can get!
Thanks for sharing your experience!!
john
Register now (free) or login to remove ads
Old 01-16-2012, 03:09 PM
35WINDOW's Avatar
35WINDOW 35WINDOW is offline
Last journal entry: I'll try again!
I think I would either find a way to Weld it completely or use something like this (either partially or fully)-you can just apply the adhesive, screw it on with sheet metal screws, let it cure, take the screws out and apply a little more to the screw holes (or weld them/bondo them)-it is the technology use on current Cars-
http://www.lord.com/products-and-so...product.xml/133
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "31 model a coupe patch panels"
ThreadThread StarterForumRepliesLast Post
More patch panelsevinthoBody - Exterior208-29-2011 08:57 AM
Patch Panelssrb23Body - Exterior309-02-2009 11:43 PM
patch panelssteve tBody - Exterior501-18-2006 06:01 PM
Patch PanelsARPEEBody - Exterior208-17-2004 10:35 PM
patch panelsSJUBody - Exterior306-04-2004 06:31 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
