Thread Tools Search this Thread share on Facebook
  #1
Old 07-12-2004, 06:00 AM
frankenvette's Avatar
frankenvette frankenvette is offline
Go ahead kid squeeze the wheez
31" tires instead of 3.73 gears?
I ran into a vendor at the Super Chevy Show this past weekend that said I should consider putting on 31" tires instead of changing my gears from 4.11's to 3.73's, as it would be the same effect? Anyone have any experience with this?
Register now (free) or login to remove ads
Old 07-12-2004, 07:31 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Last journal entry: '59 El Camino gas filler door stops
Wiki Edits: 21
Depends on what size tires you are running now but yes, it will have the same effect. Tires are exactly equivalent to gears when figuring final ratios.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
