Thread Tools Search this Thread share on Facebook
  #1
Old 03-13-2009, 08:16 AM
72fordlb's Avatar
72fordlb 72fordlb is offline
BARN BURNING BIG BLOCK!
312 info plz
me and my dad are thinking about building a 63 f100 and im think of what kind of motor to use. it has a locked up 292 y block and i want to use a 312 but in need info on them ( plz tell me went they stoped making them) i dont want to use a 50's motor i want a 60's model if nothing i will buy another 292 and hop it up.
Register now (free) or login to remove ads
Old 03-13-2009, 08:49 AM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi,
The 292-312 were built until 64, but why would you want to use either of these engines? the only good thing about the 292 is the steel crank, you would be far better off using a 289-302.
Rich
Old 03-13-2009, 09:45 AM
KULTULZ KULTULZ is offline
aka Duke of URL
The 312 has weak main webbing. The trick is to put a 312 crank into a 292. Much stronger.
Y-BLOCK INFORMATION-
-THE NEW MEL ENGINE FORUM-
Old 03-13-2009, 06:01 PM
oldbogie oldbogie is offline
I had one of these a few decades back, it made me so happy I sucked the 292 out and put a 430 in. That'll put a grin on your face. Today you need to shop the Lincoln line at the local wrecking yard for a 460, get the tranny and the slip yoke too, it'll make the swap a ton simpler for ya.
Bogie
Old 03-13-2009, 06:52 PM
72fordlb's Avatar
i want to not use any new age stuff except for the airbags im using.
Old 03-13-2009, 10:25 PM
aka Duke of URL
312's are getting fairly rare. The 4V was only available from 56/57 and the 2V from 58/60 as a MERC base engine.
Old 03-14-2009, 06:54 PM
spankys rod shop's Avatar
spankys rod shop spankys rod shop is offline
ECZ is the block code your looking for, if your really wanting one my dad has one he would probably sell. It runs and has a 4v intake 1957
Old 03-16-2009, 05:25 PM
72fordlb's Avatar
thnx but im going to use a 292 i found in my shed. oh by the way how did your ls9 camaro end up.
Old 03-17-2009, 09:52 AM
Big Don's Avatar
Big Don Big Don is offline
312 engine choice
Poor choice and hard to find parts for anymore. Why? Because they were doomed from the start for lack of good oil pressure and oil circulation. Some of the older guys will remember this. Western Auto and Sears, Firestone stores used to sell an external oiling kit to get oil to the rockers because the original set-up kept running them dry and they would fail after only a few thousand miles. I can remember my father hooking up the external oiling system years ago. It kinda worked but the oil pressure idiot light would flicker constantly. He finally gave up on the thing and put a piece of black friction tape over the light and drove it till it dropped dead. And it did!
The 292 block was much better than the 312, as far as my own ownership of several. They ran forever, but most rusted away before the engines wore out.
302 is a much better choice... bullet proof, ltsa parts and cheap to run and maintain.... Plus all the modern transmissions and add ons are available for them.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "312 info plz"
ThreadThread StarterForumRepliesLast Post
All 62 Impala/Bel Air Info (4dr Only)six-duece- ImpalaGeneral Rodding Tech212-22-2007 06:23 AM
Custom intake tube info (Cavalier, but good info for all)TheVisEngine1102-09-2007 04:44 AM
Need info about the th350 transmissionjoe350s10Transmission - Rearend107-01-2006 09:44 PM
windsor infoBlagEngine104-24-2003 08:08 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
