313ci what kind of power should I make??? NX nitrous How Fast?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-22-2013, 10:04 PM
FKR FKR is offline
I get that, I just see so many people with these crate engines then they through nitrous on them and make the same power I am for even more money. I have only paid for parts, I did all the work myself on my free time in the machine shop. I have only had to pay for parts, Less than a base performance crate engine cost. If you had to pay someone else for all of this then you are more than right, this would cost an arm and a leg for only 400hp or so naturally asperated.
  #17 (permalink)
Old 05-22-2013, 10:12 PM
vinniekq2's Avatar
If you have access to a machine shop,why not build a used part twin turbo ,ls truck engine,six liter???
  #18 (permalink)
Old 05-22-2013, 10:19 PM
FKR FKR is offline
Now that's expensive. Parts cost triple or even more than what I have spent and then another five time that for the rest of the driveline to hold that kind of power. I didn't say I had $30k to spend.
  #19 (permalink)
Old 05-22-2013, 10:40 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
My motto is 'Do what you can with what you have where you are.' I have it hanging up in the office part of my shop at work. I think you did pretty well with what you started with. I'm not a big proponent of small cube motors but this a solid build that shows the capabilities of one of the less-loved SBCs. Good on you for taking good advice when it's given as well.
The Following User Says Thank You to Valkyrie5.7 For This Useful Post:
FKR (05-26-2013)
  #20 (permalink)
Old 05-23-2013, 07:52 AM
Rhansen's Avatar
Footbraker
Nice project
Are you using a 7.5" rear or an 8.5"?
I would definitely get rid of the 7.5, broke 3 of them myself not launching harder than 1.88-1.92 60'.
It would be interesting to see some timeslips if you ever get it to the track.
The Following User Says Thank You to Rhansen For This Useful Post:
FKR (05-26-2013)
  #21 (permalink)
Old 05-23-2013, 08:27 AM
lg1969's Avatar
Google "Tunnel Ram 406"
I always like to see 307 get some respect. Always getting put down like a black sheep of the family.
The Following User Says Thank You to lg1969 For This Useful Post:
FKR (05-26-2013)
  #22 (permalink)
Old 05-23-2013, 08:08 PM
vinniekq2's Avatar
re 30K?
Originally Posted by FKR View Post
A little more update for everyone. I have the engine back out and did a little more port work to the heads (184cc intake/69cc exhaust) and intake now a 1206 gasket, while I wait on my new mechanical roller cam and the machining for the new springs and 54cc chambers for 10.8:1. Also looking into running a 750 carb with alcohol. Still looking into a better rear. Spending a lot of time learning as much as I can to make this engine work and the car to put the power to the ground for fast good consistent times. If a 305 can make 394hp n/a with stock rotating assembly (engine master challenge) Then there is no way my build can't be close or even better. I am really hoping to make over 550hp with nitrous. Some how 10.99 here I come!
You said my idea was silly? yes,you can get 550 your way
  #23 (permalink)
Old 05-26-2013, 11:28 AM
FKR FKR is offline
The rear is still a 7.5 that I built when I had my old 305 which ran 13.60's@90mph. I am getting a ford 9" to put in. Thinking of a using 4.71 gears with 28-10.50 slicks.
  #24 (permalink)
Old 05-26-2013, 11:39 AM
vinniekq2's Avatar
13.60s at 90 MPH?
  #25 (permalink)
Old 05-27-2013, 08:36 AM
FKR FKR is offline
Yes, no nitrous almost all stock engine and still had everything in it. Car weighed 3540 with me in it. I spun really bad every time. I know that's nothing to brag about but that's what I had at the time. Stock trans 200-4R and 4.56 rear gears. So what I have now is a 3000lbs car with a well built 313ci nitrous fed engine, TH350, 3700 stall and 4.10. I drove it with the flat tappet cam and it was quick on just the engine, never got to run it at the track. Now its going to have a bigger solid roller cam 555/576 238-245@.050 110lsa.
  #26 (permalink)
Old 05-27-2013, 10:36 AM
Rhansen's Avatar
Footbraker
Your mph looks awful low for the ET + tirespin....
  #27 (permalink)
Old 05-27-2013, 06:19 PM
vinniekq2's Avatar
I agree
Thats why i questioned it above?
same car with nitrous/307/4.1 gears
I would guess 13.1s if the last car went 13.6s
The MPH indicates very low horse power
  #28 (permalink)
Old 05-27-2013, 06:58 PM
Rhansen's Avatar
Footbraker
or he ran out of gear before the 1/4..........
need to see timeslips
  #29 (permalink)
Old 05-27-2013, 07:14 PM
vinniekq2's Avatar
200r4
5100 RPM will give 90 MPH with a 27 tall tire.He also said he had an over drive.Thats why I said the engine wasnt making power.
13.6s would indicate about 330 HP
90 MPH would indicate about 250 HP,or less
the numbers dont match,or it was running out of gas flow in the top end
  #30 (permalink)
Old 05-28-2013, 07:27 AM
Rhansen's Avatar
Footbraker
90 mph is usually 15's unless you cut a spectacular 60'/lift throttle/use brakes/run out of gear/run out of fuel, etc... At 13.6 I would expect to see 10x mph.
My uncle's car would run 85+ mph in the 1/8 but only mid 90's in the 1/4 due to wrong gearing and a 6k rpm limiter in the MSD box.
Is also possible the op doesn't correctly recall his ET/mph.....
How do I make a 5.0 Mustang fast? ChevelleSS Engine 20 06-07-2010 05:26 PM
What kind of HP do use think this Engine would make Hammerchvy Engine 7 11-13-2009 04:11 PM
How to make 1000 HP without a blower/turbo/nitrous Tomlowe523 Engine 36 08-03-2009 09:45 PM
best way to make a s-10 hook & how much nitrous BIGWISEXY Hotrodding Basics 4 01-11-2009 05:02 PM
Gear + Nitrous + 4 gears= how fast?????!!!! bigbad66chevelle Engine 6 06-14-2005 04:38 PM
