318 aftermarket balancer, 9/16" thicker? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2008, 01:08 PM
my new off brand damper
http://cgi.ebay.com/ebaymotors/ws/eB...name=STRK%3AME WN%3AIT&viewitem=&item=260208386861&rd=1
is 9/16 thicker than the stock damper. i was able to find a crank pulley at the junkyard that is ~9-16 shorter, a 3 belt off a 73-74 small block.
So I went from this
to this
now, the new crank pulley is a larger diameter and interferes with the water pump pulley! I have this feeling that getting the water pump pulley from the same motor would get the offset all wrong on the water pump. (mine is a '76 with just power steering)
now I dont know where to start. Suggestions?
Old 05-12-2008, 01:53 PM
Jmark's Avatar
The best place to re-start is to return the wrong balancer and find the correct one. By the time you fix the water pump problem, then the P/S problem, then comes the alternator and A/C of you have it. Sounds like you just got the wrong one, and chasing down the "correct parts", if you can find them, will take a lot longer than starting over will.
Old 05-12-2008, 02:43 PM
I think you're right
I called Raceparts, the ebay store I bought it from, and spoke with John. real nice guy, knows his stuff, and said knowbody else has had a problem, but to send it back for a refund.
Old 05-12-2008, 02:48 PM
techinspector1's Avatar
Wiki Edits: 326
Contact Damper Doctor. They can rebuild your original damper with new elastomeric material or they may have a rebuilt damper in stock.
http://www.damperdoctor.com/Merchant...egory_Code=CON
Old 05-12-2008, 02:54 PM
Jmark's Avatar
I have delt with that seller too, been very pleased. It's good he's going to refund your money.
Any chance you actually have a 272 crank? (i'm NOT a Mopar guy! LOL)
Mark
Old 05-12-2008, 03:12 PM
Mark
sure dont think so, as far as I know the motor was unmolested out of a '76 dart.
even in the pictures online, all the all metal sfi dampers look far thicker than the oem replacement ones.
Old 05-12-2008, 07:12 PM
here they are, side by side.
Old 05-12-2008, 08:13 PM
Jmark's Avatar
Maybe a difference between the two depending on factory air and non? Just guessing.
Old 05-13-2008, 12:23 AM
I had that thought too, but no online supplier shows a difference.
Harmonic Balancer help sexypizzaman Engine 4 02-11-2008 04:21 PM
69 Chevy 350 Haronic Balancer koehler852 Engine 8 12-27-2007 06:47 PM
Can I grind on the balancer? fastrehotrods Engine 4 05-19-2006 07:47 AM
Harmonic Balancer Installation DTL504 Engine 2 06-15-2004 10:17 AM
