318 car oil pan question........ - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2007, 06:28 PM
What is the difference between a 318 oil pan and any other small block Mopar. I ordered a 318 pan and its different from the one I took off. One of the end rubber gaskets don't fit because the mating surface is smaller on one end than the other and the two small holes where the gasket pops through are missing. What pan did I get.
Old 02-19-2007, 06:35 PM
DeathRattle's Avatar
Some Punk Kid
What year is the block?
Old 02-19-2007, 06:45 PM
poncho62's Avatar
Wiki Edits: 5
The SB Mopars changed their design slightly in the late 70s-early 80s....not quite sure of the year. I know that the front cover changed, so it may take a slighly different pan.
Old 02-19-2007, 06:47 PM
Some Punk Kid
Was that the poly block change? Because I think after the poly the regular 318 was same as magnum blocks.
I thought about putting that in my above post but decided not as I don't know exactly what I'm talking about.
Old 02-19-2007, 06:51 PM
poncho62's Avatar
Wiki Edits: 5
No....the poly engine was ended in 67.........They then had the 273/318/340/360 design...........They just changed this design slightly around 1980.
What year pan did you order, Grape?
Old 02-19-2007, 07:03 PM
The motor is a 318 from a '72 Plymouth A-Body, (not poly).
Old 02-19-2007, 07:08 PM
poncho62's Avatar
Wiki Edits: 5
They must have given you the later design.......
Old 02-19-2007, 07:21 PM
That's just great, I've waited about 5 weeks for this one
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Wich oil pan you use on your 383 stroker? TVR383 Engine 10 01-30-2007 07:21 PM
Stripped oil pan? zacritz929 Engine 13 01-02-2006 11:17 AM
New Cam Install - Oil pan gasket info requested. Siggy_Freud Engine 5 12-17-2004 11:00 PM
