318 need help please backfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2010, 12:10 PM
318 backfireing please help newbe
ok i took my ramcharger to get a wash and got water in the cap witch in turn fried the rotor bug so after several trips to the parts house the dist is a 90's model on an 87 truck :-/ put the new cap on and bug starts and idles fine but as soon as i pput it in gear it sputters and backfires and shakes the whole truck any help would be great
Thanks in advance
Cody
Old 10-05-2010, 12:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks in advance
Cody
Wires are crossed/out of correct order, most likely. Or you also got water in the carb, or the distributor was turned accidentally.
What is a "rotor bug"??
Old 10-05-2010, 12:25 PM
checked the wires and fireing order 3 times i think that there right is there a way to tell if it got turned
Old 10-05-2010, 12:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You didn't say what engine you have, but Chrysler V8s use the same firing order: 1-8-4-3-6-5-7-2.
Big block distributors rotate counterclockwise and small block distributors rotate clockwise.
If the distributor will turn easily- w/o loosening the hold down, I would suspect that to be the problem. You may be able to look at the distributor where the clamp is to see if there's evidence of the distributor having been turned.
The way it sounds, the timing is retarded- IF it was changed. You need to check the timing w/a timing light.
If no timing light, mark the distributor so it can be returned to the exact same position it is now in, before you move it.
Then, turn the distributor a small amount CW if a BB, CCW if it's a SB to slightly advance the ignition timing and see if it helps or not.
But ultimately, you will need to properly time the engine w/a timing light if the distributor has moved.
Good luck.
Old 10-05-2010, 01:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I see now that the title has the engine size as a 318, so turn the distributor body CCW to advance the ignition timing and see if it helps or not.
That too short edit limit really is getting to be a drag.
318 Poly performance/parts/info Abomination Engine 1 11-30-2009 05:29 PM
318 poly to 318 LA swap help needed. xpsyclonex2002 Engine 2 10-13-2008 10:28 AM
318 heads on a 360? Arillious Engine 2 07-14-2007 08:00 PM
Engine backfire fred56 Engine 3 06-04-2006 11:01 AM
oil pan for 318 mopar oldnable Engine 1 08-22-2002 01:52 AM
