318 Performance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2011, 03:33 PM
MXrider13's Avatar
318 Performance?
I was looking at a 70 Dodge D100 truck, that I am thinking about buying to be more of a daily driver and making my S10 for of just a strip car. If I get this D100 I want it to have some performance but more street friendly and occasional strip performance (maybe once every 2 months make a pass).
The D100 has a 318 in it and I can't find much info on 318 builds or performance. Just a few threads on other forums and one article in Mopar Muscle Magazine.
What should do to get more performance out of a 318, what are parts that will probably need replacing and what are common problems with the 318?
Old 07-25-2011, 04:23 PM
Clint Cummins's Avatar
hey,
Two good articles on what can be done with the 318:
http://www.popularhotrodding.com/eng...ine/index.html
http://www.popularhotrodding.com/tec...ine/index.html
Old 07-25-2011, 04:54 PM
MXrider13's Avatar
Originally Posted by Clint Cummins
Alright Thank you, Ill have to read Popular Hot Rodding more.
Old 07-25-2011, 05:57 PM
Wiki Edits: 49
Just think of the 318 as a Mopar SBC. 273, 318, 340, 360 are all of the same design and anything you would do to improve the performance of a SBC will work on a small block Mopar. Nothing cosmic about Mopar small blocks at all, although they are better in almost every respect than a small block Chevy.
Centerline
HotRodsAndHemis.com
“I wrote to the head man at General Motors and said, "I`m gonna have to desert you if you don't stop making cars for women." - John "Duke" Wayne
Old 07-25-2011, 06:46 PM
My 323 is a lil monster. Was in a 4spd 4door valiant. just as capable as a 340-360. The thing to do is use the magnum head swap. In effect results are similar to a vortec swap in terms of requirement for change. Use the GM beehive springs from a 3100 series 2 v6 engine. Mopar always had poor heads , but great oiling and rod internal provisions.
318 over 30
3.31 gear
4 speed 833
very good cam 340 mp2783 340 cam 290hp/same as 360 lil red express
Edelbrock streetmaster 0-4500 intake
1.88/1.60 heads milled .060
summit headers
GMHEI 4 pin module conversion.
Old 07-25-2011, 06:47 PM
MXrider13's Avatar
Centerline
HotRodsAndHemis.com
So would 340 heads work on the 318? I am starting to like Mopar even more from what I read.
Old 07-25-2011, 06:57 PM
they fit . There is a head gap some people live with. The cheapest way to easy street is the magnum head swap. The magnum chamber is different and has less head gap.
Old 07-25-2011, 07:17 PM
hey,
So the 90's magnum heads will bolt straight onto an 80's block?
Old 07-25-2011, 07:36 PM
MXrider13's Avatar
What about a 70s LA Block?
Old 07-25-2011, 07:53 PM
Moparts.com check the archives.
Yes.
576 heads flow about 150-155 at .500 lift. Magnums flow 219 stock and maintain high velocty for low rpm grunt.
Old 07-26-2011, 10:22 AM
MXrider13's Avatar
Yes.
I checked out Moparts and there is a lot of good info on there.
Performance Heads add in Chevy Hi Performance sdimpala64 Engine 1 04-29-2008 08:59 AM
Performance is a new one for me 63CustomCab Engine 7 01-22-2008 08:20 AM
305 performance 77formula Engine 10 11-06-2006 12:59 PM
anybody using the Jet Performance Q Jet? dion Engine 1 04-22-2004 08:02 PM
performance out of a q-jet? nitro junkie Engine 1 01-14-2003 08:58 PM
