318 poly to 318 LA swap help needed. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2008, 08:21 PM
I had to pass on the 413 I was looking at. I found a really cheap 318 instead. I have a 727 in the car now that was from the poly engine. Will a LA block bolt in where the poly used to be? The 318 came out of an RV. The poly is in a 66 coronet.
Old 10-13-2008, 10:25 AM
cope's Avatar
somebody correct me if im wrong but i think the poly uses a bigblock trans case.
u could allways measure the big block cases where a inch winder than the small block case
Old 10-13-2008, 10:28 AM
http://allpar.com/mopar/a-engines.html
318 swap to a 401?? oldnable Engine 3 02-15-2006 08:32 PM
engine swap needed joeguz Engine 4 02-01-2006 04:18 AM
What's needed for a th350 to a th400 swap? Fil Transmission - Rearend 2 09-16-2004 02:09 PM
Master cylinder swap needed Paul Gaudette Suspension - Brakes - Steering 1 05-26-2003 11:31 AM
