318 rocker chatter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2006, 06:31 AM
318 rocker chatter
Here's the scoop
new comp cam, puch rods, hyd lifters, valve springs. I am geting a chatter out of the rockers. A little louder than solid lifters.
Are the sealed pro blue head gaskets thicker than the stock dodge head gaskets and would a +.025 push rod cure this???
Thanks
Old 08-17-2006, 07:45 AM
are you using the adjustables ? or did you use shims? the shaft geometery must be correct.
Old 08-17-2006, 11:57 AM
just standard replacement rods
454 ticking about to light a match Twistedwrench Engine 40 02-12-2011 04:34 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Valves or Rocker Arms Tapping lewisdanw Engine 2 06-04-2004 03:52 AM
Are these rocker arms the same? (picture) glock35ipsc Engine 4 07-12-2003 07:43 PM
How do I stop rocker knock on a 1973 318? Lewissr Engine 1 10-21-2002 12:08 PM
