318 stalling when gas is applied, timing?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2006, 06:47 AM
Last wiki edit: Long term storage preparation Last photo:
Wiki Edits: 26
Hello all
I have my 318 working great in my '77 truck, other than the stalling problem. First, let me tell you guys what i got on it.
msd blaster 2 coil
mopar orange box
headers
true duals with h pipe and cherry bombs
super tall filter, two normal frams stacked ontop of each other.
rebuilt carter bbd carb ( i rebuilt it)
when i try womping it, it will almost instantly stop, but if i go slow on the gas, it will go fine, when i have it about mid throttle, and then i stomp on her fast, it will stutter, then will run to full roar (awesome feedback growl with the cherry bombs ) Ive tried adjusting the accelerator pump, didn't really help much
ive tried adjusting the mixture, if i tried putting it more into it, a carb backfire would happen.
with the backfire, im thinking maybe the timing is a little off, especially since i put the orange box and coil on, maybe i need to retard or advance it a few degrees, since the spark is more powerful now.
Thanx,
Jerry
Old 08-31-2006, 06:48 AM
Wiki Edits: 26
oops, wrong forum
Old 08-31-2006, 07:37 AM
Guest
How strong is the squirter? With the engine off and choke open, look down the carb and open the throttle. You should see two good streams take place, one down into both sides of the primarys.....
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
350 chevy timing tiresmoke55 Engine 7 01-14-2006 10:55 PM
Help Please? 87 Dodge mini-ram van - stalling if little gas applied jojo99 Engine 3 07-27-2005 06:19 PM
A little timing help please. Jmark Engine 21 03-08-2005 11:26 PM
All a matter of timing with BBC and an EFI? vernw Engine 13 01-20-2003 04:26 PM
