318 stay or go - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2012, 10:49 AM
Last journal entry: B-250
318 stay or go
Hello --- Newby Me--- this is a repeat of an old . I am learning how to use this site . forgive me pls. old one is 318 engine diag, 12/9.
I own a dodge B250 with a 318 manufactured in 9/93. sold as a 94 winnebago. It has 222k on it and had a average comp of 155-160. kinda tired. I recently made a long trip pullin a trailer and it ran good. I have suspected some intake manifold leaks for a while but without removing some of the crap on top of the engine its hard to get a good look at it. I have smelled antifreeze burning in very small amounts and as i have replaced all of my hoses recently am pretty sure it is not there. leak was very small and no bad signs in oil or antifreeze. I am now in a place where it is parked for a while and at last start it leaked oil and water enough to produce multiple drips from bottom of engine. Hard to tell if they are mixed or separate leaks. Oil and water still look clean. next post is update and I have started an album where you can see pics from yesterday. once again sorry for the lack of organization , I am just learnin this site. Some day soon I hope to be startin a new old project and that will be more fun to post about. thank you.
Old 12-14-2012, 10:51 AM
Well , it was warm enough today to do some comfy tinkerin. I have my suspicions but am wonderin what you all think . I have attached pictures. anyone with the time to look at them and give opinion would be greatly appreciated. Driv side- 1-156, 3-179, 5-155, 7-161. Pass side 2-162, 4-160, 6-180, 8-155.
oil and rad leaks separate . etc. oil leakin into 3&6 comp up. substantially more rad fluid after comp test. definitely running down engine.
gotto go . more later.
Thank You
Old 12-14-2012, 11:03 AM
Goin back out today to see if I can find coolant leak. wondering if it could be coolant passage in head or intake manifold to exterior of engine. dont know if i want to do head gasket in drive this time of year. I t could still be a hose as there are ends that cant b seen without removing stuff in front. and yes I know valve cover gaskets are on the list if I dissasemble.
I think the higher comp readings this time mean oil leaking into cylinders and temp sealing rings. dont know if that would b head gaskets or valve sleeves. head bolts have never been retorqued.
at any rate it is old . if i can cet it running and not leaking I would b able to use it for a light duty runnin around and campin vehicle. I know i need a new work truck if I am to carry loads as i have in the past.
Old 12-14-2012, 11:46 AM
Dose it have stock water pump ? If its dose maybe its that
The Following User Says Thank You to fordss For This Useful Post:
93B250318 (12-14-2012)
Old 12-14-2012, 12:46 PM
Has been replaced a while ago with gold napa. and I can see mating surfaces are dry. seems to be running down from behind that which would make it that funky little hose that is very difficult to see or maybe intake man coolant passage . I am looking for a coolant passage diagram without subscribing to a trade site.
Old 12-14-2012, 12:51 PM
also wondering about discolored plug 3 and comp up in 3 and 4. does my guess make sense. see above post. there are pics in an album.
Old 12-14-2012, 01:01 PM
also i guess i dont really like sealer but if i could find the leak as a gasket i may just pour a bottle in.
this is kinda gettin to b a mis use of a hot rod site it seems to me so while suggestions are still welcome . I am also lookin elsewhere for info.
thank you all.
Old 12-14-2012, 01:51 PM
never mind . i forgot about the therm housing. and that is the coolant culprit. ouch . gotto take all that crap off for a 50 cent fix.
I am still wonderin about the discolored plug and the compression readings . I will start another thread later but for now. therm gasket.
thank you
Old 12-14-2012, 02:12 PM
Banned
check the core plugs near the motor mounts..
The Following User Says Thank You to gearheadslife For This Useful Post:
Old 12-14-2012, 06:32 PM
455olds's Avatar
If oil in the cylinder brings compression up your rings are not sealing well. If the plugs in those cylinders are oily then you are getting blowby. Both these would need a rebuild to fix correctly. I would keep the engine and rebuild unless you want to step up to more cubes.
The Following User Says Thank You to 455olds For This Useful Post:
Old 12-15-2012, 05:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Most often coolant leaks down the side of the block is going to be freeze plugs rusting out. Often they are very hard to get to. If you can get the old one out, you can use an expandable rubber plug (example below) as a stop-gap to hold you over. They tighten w/a wrench or socket so no need to hammer them in place. If one is leaking the others aren't far behind, either.
But by the sounds of it it's time to rebuild it/replace it w/a 360 anyway.
318 poly to 318 LA swap help needed. xpsyclonex2002 Engine 2 10-13-2008 10:28 AM
1974 Dodge Dart Custom 318 oil in muffler/wont stay running Dalles Engine 11 12-12-2006 11:09 AM
Should it stay or should it go jd71cam Body - Exterior 2 11-14-2006 12:52 PM
Should it stay or should it go? Camaroman16 Hotrodding Basics 0 09-23-2004 03:52 PM
How to stay healthy 406chevelle Hotrodders' Lounge 3 02-11-2004 10:47 AM
