318 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2006, 09:14 PM
318 stroker
just wondering if there is a way to stroke a 318 engine any information would be greatly appreciated. trying to get what i can get out of this engine thanks
Old 02-20-2006, 09:22 PM
wayneair's Avatar
slinky+esculator=infinite fun
is it a SBC?
Old 02-20-2006, 09:25 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.speedomotive.com/mopar_31...50_stroker.htm
http://www.speedomotive.com/318%20TO...OKER%20KIT.htm
Old 02-20-2006, 09:26 PM
WV hillbilly
Last journal entry: PTL 220CC
Originally Posted by wayneair
is it a SBC?
likely its a mopar, check out speed-o-motive.com
2wld4u
BEAT ME TO IT...
yeah, what he said....^^^^
Old 02-20-2006, 09:59 PM
wayneair's Avatar
318----SBC....holy gee whiz... what was i thinking?
Old 02-20-2006, 10:01 PM
wayneair's Avatar
isn't the 318 essentially the same block as the 360, 5.2 L & 5.9 L?
Old 02-21-2006, 08:39 PM
318 stroker
thanks for the info guys keep up the good work and fast responses
Old 03-06-2006, 08:50 PM
318 stroker
318 and 340 engines use the 3.31 stroke crank while the 360 crank has different crank journals and stroke. They're not interchangeable. B and RB engines can swap cranks by machining bearing journals of RB crank. Don't know of small block Mopar interchanges. There are a number of small block Mopar strokers running around now.
302, biggest stroker capacity? 6-712dr73xa Engine 7 02-03-2006 12:28 PM
Ford 532 stroker Jared Engine 12 05-09-2005 08:11 PM
383 Stroker kit on Ebay any good? sb72elcamino350 Engine 1 03-04-2004 09:02 PM
318 stroker tad Engine 12 02-04-2004 01:42 PM
oil pan for 318 mopar oldnable Engine 1 08-22-2002 02:52 AM
