Thread Tools Search this Thread share on Facebook
  #1
Old 05-13-2009, 06:06 AM
Jacks73 Jacks73 is offline
318 vs 340
Currently the car has an original 318 with factory AC; I have a '72 340 bare block with 2.02 heads. How many parts can I use from the 318 to build the 340?
I’ve been told that all I need to purchase are pistons, cam, 4 bbl intake, and exhaust manifolds. Everything else can be used, i.e. crank, rods.
Register now (free) or login to remove ads
Old 05-13-2009, 07:40 AM
engineczar's Avatar
engineczar engineczar is offline
The 318 and 340 used the same length rods, same stroke and same journals sizes so fundamentally you can use the crank and rods. I'm not entirely sure if the 318 components are as strong as the original 340 parts or not. The early pre'72 340's used a steel crank not cast. I'm not sure if the 318 crank is forged or cast but depending on the HP level you're seeking it may not matter so long as it is crack-free.
The bigger question to answer is what sort of compression ratio you're trying to obtain. The early 340's came through with 10.5:1 compression which was created with pistons that protruded above the deck and were matched with open chamber heads. Trying to obtain something in the 9.5:1 range and maintain a .04 or so quench is a challenge with those open chamber heads.
BSE Racing Engines
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "318 vs 340"
ThreadThread StarterForumRepliesLast Post
318 poly to 318 LA swap help needed.xpsyclonex2002Engine210-13-2008 10:28 AM
question on 318 magnum engine in street rod34pfxxEngine406-26-2008 11:16 PM
340 head on 318 ?chevrolet327Engine807-15-2007 04:50 PM
How do I identify a 318, 340, 360 Mopar??STATUTORY GRAPEEngine404-19-2006 08:15 PM
oil pan for 318 moparoldnableEngine108-22-2002 01:52 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
