Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 12-16-2002, 05:47 PM
lnwlf lnwlf is offline
Post 31ford to sway bar or not to?
Aftermarket IFS don`t seem to have a front sway bar. Stock Mustang II has a front sway bar. Pro`s vs Con`s thanx Paul
Old 12-17-2002, 04:47 AM
badA31 badA31 is offline
Smile re: 31ford to sway bar or not to?
inwlf, Quite a number of years back I saw a tech article on installing such a bar on a model A with the M-II suspension. It didn't look too good. I've had mine on the road for 14 years with a stock M-II which I installed. The Kits back then were few and poorly designed. The A is a high center of gravity car and was never designed to go over 45 or so. Even with a fairly tame small block in them, we're pushing it. Mine drives very well and as long as you aren't trying to stuff it into high speed turns I just don't see that it's worth the effort. I do get some lean in tight turns at turnpike speeds but it's fine otherwise. If you push a model A above 70 you better be going in a straight line!!!
Old 12-17-2002, 06:18 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Gassers were best!
Post re: 31ford to sway bar or not to?
Sway bars are a good idea on any car. I put one on the rear of my Willys and greatly helped previous body lean problems. Great tip; I use sway bars from front ends of Ford Courier pickups. Can be adapted to any rear end and many front ends.
Old 12-17-2002, 11:52 AM
F-1Rodder's Avatar
F-1Rodder F-1Rodder is offline
My F-1 has a Gen 1 Camaro front clip. As you know, pickups tend to sit higher, though mine is lowered quite a bit. I fabricated a sway bar for the front from an S10 or equavlent sized Ford small pickup. Before the sway bar I had a fair amount of body lean on corners. After the sway bar the truck leans way less on the corners. I drive it like it was a sports car. I mean I can really push it in the mountain curves and it just plain carves out great confident feeling lines. I highly recommend doing it.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
