Thread Tools Search this Thread share on Facebook
  #1
Old 07-08-2011, 09:45 PM
NudeAutoMall NudeAutoMall is offline
Alternative Roddin RRR
Last journal entry: Fire Water
Last classified ad: 55 Post
32 Chevy Dimensions?
32 Chevy Dimensions? Building a Rat Rod from a junk 32 Chevy Coupe. Half the passenger side and almost 100% 0f the driver side has gone to rust heaven. Anyhow looking to hang this piece of rust on a roll cage only I don't have enough car to take any measurements. I need measurements across the inside of the car at the rear door post. Rear post to rear post, at the floor, at the body line, and at top of door, if anyone can?
Thanks.
Register now (free) or login to remove ads
Old 07-09-2011, 03:16 AM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
You need to know if it is a Master or Standard. The dimensions are different..
Old 07-09-2011, 10:02 AM
I would believe her to be a 5 window Standard.
Here is a pick, but it doesn't show the Chevy very good; the rest of my pix are tied up on the crashed computer till I recover them.
Old 07-22-2011, 11:17 AM
Just a follow up to help others that stumble on this post.
Sometimes my pore spelling is a good thing, searched for dimentions instead of dimensions and got results.
This is dimensions across the bottom of the rear quarters at the door:
3 Window, outside dimensions 42"
5 Window, inside or out not specified, 46 5/8"
Now time to get back to my A 32 Chevy
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "32 Chevy Dimensions?"
ThreadThread StarterForumRepliesLast Post
Chevy Trans Mount DimensionsOld Rotor FlapTransmission - Rearend102-06-2010 07:03 PM
48-53 chevy truck frames dimensions..NEW INTERIORSSuspension - Brakes - Steering901-22-2010 02:36 AM
Need 56 Chevy splash pan dimensionsmr52pickupBody - Exterior202-28-2007 02:04 PM
33 Chevy Frame DimensionsJDTravelerGeneral Rodding Tech901-29-2006 05:54 AM
Chevy specs and dimensionsotis84Engine310-31-2004 10:59 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
