32 Ford 2dr sedan body weight ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 07:06 PM
Last journal entry: Bringing home the 401 Nailhead
Anyone have an idea of the body weight of an original all steel 32 Ford 2dr sedan (body only - no fenders or running boards)? Having trouble obtaining enough manpower and just wondering of I can hoist it from my 2X10 trusses.
Old 09-27-2006, 09:17 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Check out this thread I found while using the search function on this site:
body weight?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 09-27-2006, 11:53 AM
Thanks
I had found and read that thread before. I was concerned that the steel on the 32 was a much heavier gauge than what was discussed. I take it from your reply that this formula will still put me in the ball park.
Thanks again
Old 09-27-2006, 12:10 PM
I did a 32 Ford sedan ... with the doors off ... It is about the same as my 3W ... weight wise ... for the sedan ... I was alone so ... I used a engine lift ... I had a 2X6 run thru the front where the doors go ...
I had a pair of Saw horses ... on each side and I ran a 2 X 6 under the body ...
Went to the rear and repeated the procedure ...
Then rolled the chassis out ... then sat it down on my body dolly ...
I have a wooden rolling body dolly ... that I built to keep the 32's on when I am doing them ...
So far ... 2 Roadsters, 1 5W coupe, 1 3W coupe and 2 sedans ...
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Matching hood to body '32 Ford cares Body - Exterior 13 06-05-2006 11:15 PM
39 & 40 Ford body? Gene Boyd Body - Exterior 1 03-01-2002 04:17 PM
32 Ford Coupe Body LoTempio Body - Exterior 4 01-29-2002 12:03 PM
