Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 32 ford body info
Old 09-29-2010, 06:54 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally Posted by theft
...I hope you can help me, I'd really like to play the quarter similar to the original
I've never been able to find the precise and exact type of measurements you would need for a deuce body anywhere on the web. The problem is that while these bodies may appear somewhat flat and boxy they are, in fact, fairly complicated. Any dimensions you might find on the web will probably be for very limited cross sections of the body. If you want to build an exact replica, I can't imagine doing that without an original in front of you to work from. And from my limited experience, you'll need to have access to that original throughout almost the entire fabrication process.
I don't want to sound too pessimistic here or discourage you from attempting this project, but if this is your first shot at fabricating a body, I would recommend keeping things as simple as possible and shooting for something that might be eye catching and "era correct", but not necessarily an exact replica.
I'm not sure this will be of any help to you but you can see the entire step by step design and fabrication of the roadster shown above by going to this journal. You can also see the step by step design and fabrication of the sedan deliver pictured below by going to my other journal here. Obviously these bodies are not exact replicas of anything...but I believe they do convey the line and the feel of many late 20's and early 30's cars. And they were far simpler than attempting an exact replica.
Always learning...and sharing what I've learned.
