32 Ford Chassis - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2002, 05:18 AM
Post 32 Ford Chassis
  • I am setting up a new 32 Ford Frame and need
    help with frame width dimension, I need to confirm the width at front & rear horns, and at the first bolt hole in front of the rear end.
Old 02-21-2002, 05:40 AM
New Member
Post
you tried classic chevy on s.e 89 at i-35
Old 02-21-2002, 05:43 AM
New Member
Post
guess i got chevy's on my mind this morning,i meant obsolete ford right next door,they have several new frames sitting around,take your tape measure
Old 02-21-2002, 06:30 AM
Post
width at the rear of a 32 is 40" and one sixteenth. Now that is at the absolute rear, width twenty and a half inches up from that is 40 and a quarter of a inch. As far as the front, extreme front width is 23 and three quarters. At front axle centerline it should read 25 and three quarters. all measurements are to the outside. The first hole in front of rear axle centerline should show a frame width of 43" , that hole should be 14 and one quarter of a inch foward of axle centerline.
Old 02-21-2002, 12:53 PM
Post
If you have access to a Wescotts catalogue, they have the dimensions for a bunch of old ford frames ! :-)
Good luck
