32 Ford Condencer Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2013, 11:27 AM
Hi Guys, I am new to the forum. Building a 32 Ford 5 window coupe. I have a Walker Radiator with an air conditioner condenser (21" highx13"wide and 1-1/4 " thick). It will fit in the grill shell but the grill will not fit, condencer too thick. What are you guys using?
Old 02-26-2013, 01:53 PM
sedanbob's Avatar
I have a '33 with an A/C condensor in front of my radiator - also a tight fit. My condensor came from Vintage Air, and is about 3/4" thick. I don't know if that 1/2" difference is enough to help you or not.
Welcome to the forum.
Old 02-27-2013, 06:32 AM
Thanks, Sedan Bob, I will contact Vintage Air. 1/2 inch WILL help a lot! I am sure that I will have a lot more questions. Thanks again.
1948 Ford stock engine/tranny with Ford 9" rear end beek15853 Transmission - Rearend 5 04-04-2012 07:56 PM
1934 Ford transmission with1948 Ford truck engine clutch questions ppetrano Transmission - Rearend 1 05-20-2011 11:02 AM
Need advise on Ford 300 engine swap to a Ford 400 aztek_warrior Hotrodding Basics 6 03-22-2011 02:59 PM
1948 ford f-1, 1981 ford f-150, mustang ll pile up derrick_500 Suspension - Brakes - Steering 6 09-09-2008 01:17 AM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 09:17 AM
