32 Ford Coupe, Transmission suggestion - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2011, 01:48 PM
1bad32's Avatar
I'm having a '32 Ford Coupe built with about 560 hp up front.
The tranny is going to be 700r4,,will that be good for the hp?
Your suggestions are welcomed.
Thanks
Old 10-16-2011, 01:59 PM
So much depends on the build you are planning. Are you talking about 560hp @ 7000 rpm from a built SBC, or 560hp @ 5000 rpm from a high-torque big block? How much money are you planning to pour into the 700R4 to beef it up for this duty? Have you considered one of the newer GM automatics instead?
Old 10-16-2011, 02:21 PM
1bad32's Avatar
I didn't know about the GM autos,,,any part #'s?
The engine is a stroked chevy 383 and it does have a 6-71 blower.
Here's a pic and thank you for any ideas!
Old 10-16-2011, 02:56 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
If the car is light enough, hopefully the tires just spin without breaking the tranny.
For overdrive transmissions, a 4l80e is stronger but requires a stand alone computer to run it.
Old 10-16-2011, 03:22 PM
1bad32's Avatar
I was reading about the 4r75e tranny,,it's suppose to be good up to 600 hp?
Old 10-16-2011, 05:10 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
I've never seen a Ford tranny bolted up to a SBC.
Old 10-16-2011, 07:47 PM
1bad32's Avatar
Excuse My lack of knowledge,,but what's an SBC??
Thanks
Old 10-16-2011, 09:14 PM
Small Block Chevy
Old 10-16-2011, 09:43 PM
1bad32's Avatar
Well like I said,,I'm having a shop build me a '32 coupe with the above engine and they always use SBC engines with Ford trannies I guess because the frame is a Ford frame?
I want to make sure I put in the right tranny for the hp and tq the engine will produce.
I had a 2006 Corvette{just sold} with over 560 rwhp so I know I'll need a good tranny on tis coupe!
Old 10-17-2011, 01:27 AM
327NUT's Avatar
Ok no offence, we all were new to the hot rod scene at one time so I'll base your statement about your shop using Ford transmissions with a sbc on your lack of knowledge. "Almost" NO BODY uses a Ford trans behind any kind of Chevy engine....period. There's just no reason to, 1st, they won't bolt up w/o an adapter, 2nd, the Chevy 700R4, 4L60, 4L80 built properly will be a perfect trans for what you're doing. The 4L60 & 80 are stronger, in regards to the Ford chassis, any trans will fit.
Just a word of caution, your hot rod shop might be the most honest guy's in the world...I hope they are but you really need to educate yourself on this build you're undertaking.....and/or find a friendly knowledgeable street rodder who can go with you, look at the car and the prices this shop is charging you for parts. Believe me when I tell you that a LOT of guy's get screwed big time when they don't know anything about hot rods and have someone else build it for them. Hopefully yours isn't the case...but it surely wouldn't hurt to look into it. Good luck
Old 10-17-2011, 01:29 AM
As a long time real 32 Ford owner ...
I have NEVER heard of using a Ford based automatic behind a small block Chevrolet engine.
You can go here to see a journal of the build on my 32 3W coupe.
http://www.hotrodders.com/forum/jour...ge=5&reverse=1
I would imagine ... that the frame for you NEW toy is a reproduction one ... never to have ever been close to a Ford plant. Same for the body. NOTHING wrong with that at all. A LOT of the " 32's " being built are reproductions. Both fiberglass and steel repro bodies are now available.
Post up some photos of the new built ... we are such a visual bunch
DEUCE ... Moderator
Old 10-17-2011, 03:24 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
The 4L60 and 700R4 are the same unit. 4L60e also has the same guts.
The 4L80e is the stronger of the two.
I'm sure you meant this, just wanted to clarify for the OP.
Old 10-17-2011, 05:53 AM
Here is a 700R4 built to withstand 700 Horsepower.
http://www.transmissioncenter.net/pe...ive.htm#Stage4
No adapters needed. I have a built 700R4 in my 1932 Ford 3W coupe. My engine is " only " 430 horsepower but I do have a NOS shot plate on it with a 225 rating. 430 plus 225 equals 655
My 700R4 did require a bunch of upgrades and a special nitrous rated converter. With street tires ... the car HOOKS pretty hard without the NOS. With it ... tire smoke city.
Old 10-17-2011, 07:11 AM
1bad32's Avatar
Thanks for all the help,,I will contact My shop today and clear up some issues!
Old 10-17-2011, 07:21 AM
1bad32's Avatar
No disrespect,,but if you look at the op,it does say that They will be using a 700r4 tranny.
I do believe that is a GM tranny,right?
I just wanted advice on using maybe a "stronger" one for the amount of hp that my engine will be making,,or will the 700r4 be ok.
Thanks
ThaNKS
1941 chevy coupe transmission stumpwi Suspension - Brakes - Steering 0 10-26-2009 01:27 PM
FMX Transmission into a 1940 Ford coupe 4041Ford Hotrodding Basics 7 08-20-2009 09:49 AM
Floor shifter Transmission for 1940 Ford Coupe? alesi40ford Transmission - Rearend 6 01-05-2009 11:30 AM
1954 Ford Coupe Transmission problem Neal0o Transmission - Rearend 7 09-15-2005 12:17 PM
"49" Ford Business Coupe Custom Transmission Swap standard to late model Automatic Rockin Rick Transmission - Rearend 4 10-14-2003 01:40 PM
